location of each cell
Old   October 2, 2012, 15:52
Default location of each cell
hawkeye321 is an unknown quantity at this point
hey, does anyone know how can I get the x, y and z of each cell?
hawkeye321 is offline   Reply With Quote
Old   October 3, 2012, 02:02
Bernhard
Bernhard is on a distinguished road
Did you try searching the forum? This question has been answered a few times already.
http://www.cfd-online.com/Forums/ope...ordinates.html
http://www.cfd-online.com/Forums/ope...ll-center.html
Bernhard is offline   Reply With Quote
Old   October 3, 2012, 10:50
Thanks Bernhard!
Old   November 16, 2012, 13:10
Default cell information
Jamal
aujamal20 is an unknown quantity at this point
Dear
I am new to OF and working on heat transfer problem. I defined a simple 2D rectangle (mesh 100*200) having inlet at topleft corner and outlet at bottom left corner.
I need the cell id next to top/bottom/etc patches to get averaged field values. Currently I dont know how i can get cell id or cell (xyz) by using mech.C(). Please tell me precisely what and where i have make changes in case directories to get this.
thanks in anticipation...
aujamal
aujamal20 is offline   Reply With Quote
Old   November 16, 2012, 13:15
do you mean ID of the cell adjacent to the top and bottom boundaries?
Old   November 16, 2012, 14:10
Bernhard
Originally Posted by aujamal20 View Post
Dear
aujamal
What are you trying to achieve exactly? I think you can achieve it by using the sample utility, or putting functionobjects in the controlDict.
Old   November 17, 2012, 15:15
Jamal
Dear
Thanks alot for your response. As I have mentioned earlier that I am having a 2D rectangle, mesh (100*200) and therefore there are 100 cells in each row having 200 rows. I need to calculate the average value of temperature field in each row by taking the cell values. Now I need cell ID or cell xyz (location) of every cell in the domain (100*200) so that I can sort them row by row accordingly.
So let me know that how I can do this in a better way and how to set sample utility or functionobjects in condtrolDict to achieve this.
thanks
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
How to determine the location of the cell center zmester Main CFD Forum 0 October 11, 2009 06:58
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
