November 20, 2012, 12:17 |
Gmsh+SimpleFoam issue
Hernán
Hi, I'm sorry for my bad English.
I'm new in this forum and with OpenFoam, and I'm trying to run with simpleFoam the flux of water in an elbow. For that I've made the mesh with Gmsh and exported to Foam with gmshToFoam command. Checking several discussions in this blog I formulated the different support archives, but when I try to run it, I just got few time's evaluations and I notice that the values of U, p, k, epsilon increases rapidly without a convergence. I tried changing the mesh dimensions, changing time interval, and other different options but the result is the same: DIVERGENCY!!! I appreciate if any of you can help me giving me a light with the reason of this problem, cause I'm a kind of desperate with this issue because I need this for my graduation. This is the error message that I got on the 6th iteration: #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #5 Foam::fvMatrix<double>::solve() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so" #7 in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/simpleFoam" #8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #9 in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/simpleFoam" Excepción de coma flotante (`core' generado) |
elbow flow, gmsh, simplefoam convergence, simplefoam stability |
Display Modes | |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
simpleFoam serious mass balance issue | fivos | OpenFOAM Running, Solving & CFD | 2 | November 6, 2011 09:21 |
[Gmsh] gmsh SIMPLEFoam error | pcaste12 | OpenFOAM Meshing & Mesh Conversion | 8 | June 26, 2011 12:45 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
Issue with SimpleFoam with Sharp corners | kdneroorkar | OpenFOAM Running, Solving & CFD | 13 | September 15, 2008 19:12 |
