Hanzo |
November 21, 2012 02:17 |
How to convert psiChemistryModel for multi Zone?
I am currently working on a code to use chemistry in different zones. I started with chtMultiRegionFoam solver as basis source code. I basically try to realize chemFoam behavior for all fluid zones (solid zones are removed completely).
So far, I managed to read initial conditions, chemKin input files and chemistry properties for each region. The next step is to create an instance of psiChemistryModel for each region. In chemFoam (or rhoReactionFoam) this is done doing the following:
http://foam.sourceforge.net/docs/cpp/a03249_source.html
00026 Info<< nl << "Reading thermophysicalProperties" << endl;
00027 autoPtr<psiChemistryModel> pChemistry(psiChemistryModel::New(mesh));
So in a regional context the variable mesh should be replaced by the mesh of the current region which is stored as fluidRegions[i]
autoPtr<psiChemistryModel> pChemistry(psiChemistryModel::New(fluidRegions[i]));
Compiling works fine but when OpenFoam initiates the chemistryReader I get a floating point exception:
Reading initial conditions.
Adding to YdefaultFluid
Selecting psiChemistryModel ODEChemistryModel<gasThermoPhysics>
Selecting thermodynamics package hsPsiMixtureThermo<reactingMixture<gasThermoPhysics>>
Selecting chemistryReader chemkinReader
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::fvPatchField<double>::operator/=(Foam::fvPatchField<double> const&) in "/home/florian/OpenFOAM/florian-2.0.x/platforms/linux64GccDPOpt/bin/multiRegionChemFoam"
#4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator/=(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#5 Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > >::correctMassFractions() in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#6 Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > >::multiComponentMixture(Foam::dictionary const&, Foam::List<Foam::word> const&, Foam::HashPtrTable<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > >, Foam::word, Foam::string::hash> const&, Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#7 Foam::reactingMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > >::reactingMixture(Foam::dictionary const&, Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#8 Foam::hsPsiMixtureThermo<Foam::reactingMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > >::hsPsiMixtureThermo(Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#9 Foam::hsCombustionThermo::addfvMeshConstructorToTable<Foam::hsPsiMixtureThermo<Foam::reactingMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#10 Foam::hsCombustionThermo::NewType(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#11 Foam::psiChemistryModel::psiChemistryModel(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so"
#12 Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > >::ODEChemistryModel(Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so"
#13 Foam::ode<Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > >::ode(Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so"
#14 Foam::psiChemistryModel::addfvMeshConstructorToTable<Foam::ode<Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so"
#15 Foam::psiChemistryModel::New(Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libchemistryModel.so"
#16
#17 __libc_start_main in "/lib/libc.so.6"
#18
浮動小数点例外
I assume that the call psiChemistryModel::New(fluidRegions[i]) uses the appropriate region mesh but does not load T,p, and Y fields from the $CASE_DIR/0/region/ folder.
In chtMultiRegionFoam there is an analog line where the current region mesh is plugged into a constructor of similar type (it only takes a const mesh as input):
http://foam.sourceforge.net/docs/cpp/a02601_source.html
except that here the result is stored in a pointer list.
So I wonder if anybody has an idea why I cannot do this in the same manner for the psiChemistryModel constructor.
Any hints or comments are highly appreciated.
