Home > Forums > OpenFOAM
multiphaseEulerFoam - UEqn
Old   November 21, 2012, 13:52
Default multiphaseEulerFoam - UEqn
mikeP is on a distinguished road
I see that in mEF, the phase intensive formulation is not used.
Instead we have the UEqn as:
(scalar(1) + fluid.Cvm(phase)/phase.rho())*
                  fvm::ddt(alpha, U)
                + fvm::div(phase.phiAlpha(), U)
                - fvm::Sp(fvc::ddt(alpha) + fvc::div(phase.phiAlpha()), U)
              - fvm::laplacian(alpha*nuEff, U)
              - fvc::div
                    alpha*(nuEff*dev(T(fvc::grad(U))) /*- ((2.0/3.0)*I)*k*/),
                    "div(Rc)"
              - fvm::Sp(fluid.dragCoeff(phase, dragCoeffs())/phase.rho(), U)
            //- (alpha*phase.rho())*fluid.lift(phase)
              + (alpha/phase.rho())*fluid.Svm(phase)
isn't there something wrong here?
1) why is the term ((2.0/3.0)*I)*k) commented out?
2) shouldn't it be
alpha*(nuEff*dev(symm(fvc::grad(U))) /*- ((2.0/3.0)*I)*k*/),
instead of
Thanks
mikeP is offline   Reply With Quote
Old   November 22, 2012, 18:39
isn't this part:
              - fvc::div
                     "div(Rc)"
should be like this?
- fvc::div
                     alpha*(nuEff*2*dev(symm(fvc::grad(U))) - ((2.0/3.0)*I)*k),
                     "div(Rc)"
Old   November 26, 2012, 12:40
Kent Wardle
kwardle is on a distinguished road
I can check into this, but I think the answer is that mEF was written with LES only in mind and is not set up for RAS turbulence at all.
-Kent
kwardle is offline   Reply With Quote
Old   December 18, 2012, 15:25
Yanxiang Shi
yanxiang is on a distinguished road
hmm... This is weird. It this OF210 you are using? In OF211, it is formulated as follows:
    UEqns.set
        phasei,
        new fvVectorMatrix
            fvm::ddt(alpha, U)
          + (alpha/phase.rho())*fluid.Cvm(phase)*
                fvm::ddt(U)
              + fvm::div(phase.phi(), U)
              - fvm::Sp(fvc::div(phase.phi()), U)
          - fvc::div
                "div(Rc)"
          - fvm::Sp
                slamDampCoeff
               *max
                    mag(U.dimensionedInternalField()) - maxSlamVelocity,
                    dimensionedScalar("U0", dimVelocity, 0)
               /pow(mesh.V(), 1.0/3.0),
                U
It seemed the first term has been split into two parts. Do you have any idea what the difference is between phase.phiAlpha() and phase.phi()?
Thanks,
Yanxiang
yanxiang is offline   Reply With Quote
Old   March 22, 2013, 06:34
I am bumping up this thread, but there is something strange with twoPhaseEulerFoam when I compare its code in OF2.0, OF2.1, and OF2.2
In OF2.0, there is the term with the turbulent kinetic energy in the definition of the reynolds stresses, as it should.
see line 21 in (https://github.com/OpenFOAM/OpenFOAM...erFoam/UEqns.H)
But this term is vanished in 2.1 and 2.2.
why is that?
Thread Tools
Trackbacks are On
A question about UEqn sonicFoam lfgmarc OpenFOAM Programming & Development 6 February 1, 2015 17:49
solving the momentum equation in UEqn. callahance OpenFOAM 2 October 18, 2012 09:38
UEqn in cavitatingFoam Alexanger OpenFOAM Running, Solving & CFD 0 July 19, 2011 09:12
Source term problem in UEqn of simpleFoam fisch OpenFOAM Programming & Development 1 June 17, 2011 10:57
interFoam Ueqn alvin11 OpenFOAM 2 December 2, 2010 02:28
