GAMG issue
Old   December 2, 2012, 15:35
Default GAMG issue
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAMers,
I am solving a chtMultiRegionSimpleFoam case. On the air domain, for p_rgh, when I used GAMG solver, I got floating point exception right away, however, when I switched to PCG with DIC preconditioner, the case run fine - just converging slower. I am wondering what settings I can change to resolve the GAMG issue.
Thanks!
Pei-Ying
GAMG setting used:
p_rgh
solver GAMG;
tolerance 1e-7;
relTol 0.01;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
maxIter 100;
PCG that worked
solver PCG;
preconditioner DIC;
tolerance 1e-7;
relTol 0.01;
error messages:
#0 Foam::errorprintStack(Foam::Ostream&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#2 in "/lib64/libc.so.6"
#3 FoamdICPreconditioner::calcReciprocalD(Foam::Field <double>&, Foam::lduMatrix const&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#4 FoamdICPreconditionerdICPreconditioner(Foam::lduMa trix::solver const&, Foam::dictionary const&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#5 Foam::lduMatrixpreconditioner::addsymMatrixConstru ctorToTable<FoamdICPreconditioner>::New(Foam::lduM atrix::solver const&, Foam::dictionary const&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#6 Foam::lduMatrixpreconditioner::New(Foam::lduMatrix ::solver const&, Foam::dictionary const&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#8 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#9 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#10 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#11 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libfiniteVolume.so"
#12 Foam::fvMatrix<double>::solve() in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/bin/chtMultiRegionSimpleFoam"
#13
#14 __libc_start_main in "/lib64/libc.so.6"
#15
at /home/abuild/rpmbuild/BUILD/glibc-2.15/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
phsieh2005 is offline   Reply With Quote
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
GAMG solver causes troubles colinB OpenFOAM Running, Solving & CFD 5 June 13, 2013 07:48
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 02:09
rhoPorousMRFSimpleFoam/compressor simulation blows up mpat OpenFOAM Running, Solving & CFD 2 August 10, 2012 09:52
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
