Home > Forums > OpenFOAM
pyFoamPlotRunner on network
Old   December 9, 2012, 17:25
Default pyFoamPlotRunner on network
anonymous
PeterX30 is on a distinguished road
I have used succesfully pyFoam on a single node multi core hardware.
Recently I extended to a small cluster with 3 nodes (8 cores + 12 cores +12 cores with in total 32 cores)
On this 3 node configuration I`m able to run succesfully a parallel job under mpi. Here is an example how I can succesfully start a parallel pimpleFoam run on all nodes:
mpirun --hostfile hosts -np 32 pimpleFoam - parallel
In order to plot on the fly residuals, I used to apply pyFoam. On one node this is working well. Example for the corresponding job (the first node has 8 cores listed in hosts):
pyFoamPlotter.py --machinefile=hosts --proc=8 --progress pimpleFoam
Unfortunately this is not working if I start it on all 3 nodes:
pyFoamPlotter.py --machinefile=hosts --proc=32 --progress pimpleFoam
The general log file in the ~/.pyfoam/log directory contains the following warning:
WARNING Not deregistering, because it seems we were not registered in the first place - in FoamServer.py:511
What is going wrong? I thouht I have defined all required paths on all nodes ... Any idea?
Thank`s a lot for your support.
PeterX30 is offline   Reply With Quote
Old   December 11, 2012, 13:39
Assistant Moderator
Bernhard Gschaider
That log entry ("not deregistering") isn't the problem. It has to do with something completely different (the Meta-Server. See the "Happy Foaming" presentation from Montreal) which you probably are not using.
@pyFoamPlotter.py: you mean pyFoamPlotRunner.py, right?
Anyway: that happens after you start the run on the cluster (as I said: the log-entry is not the problem)?
BTW: Usually if you specify a machinefile then PyFoam should calculate the -np automatically
For calculations on a cluster I usually recommend to write output to a logfile (either with pyFoamRunner.py or a simple redirect) and then using pyFoamPlotWatcher.py on that output. That way the running of the solver is detached from the display
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 12, 2012, 16:28
anonymous
Off course, a typo. I mean pyFoamPlotRunner.py as stated in the title of the thread.
I checked your proposal and this works fine on the fly when I start "pyFoamPlotWatcher.py logfile"
on a second terminal accessing the corresponding logfile. Thank's a lot!!!
Thread Tools
Trackbacks are On
IcePak network objects in parallel solver Alexey FLUENT 1 December 25, 2013 09:32
License server out of workstation network L3munoz FLUENT 1 July 20, 2012 09:40
48 Core Cluster - GigE Network ronaldalau Hardware 2 September 9, 2011 13:50
Initialization of fluid network Liang Huang Main CFD Forum 0 September 23, 2004 03:10
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
