-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   which solver (tutorial) is for heat transfer between fluid and solid? (http://www.cfd-online.com/Forums/openfoam/110537-solver-tutorial-heat-transfer-between-fluid-solid.html)
mxylondon December 13, 2012 13:49
Hi guys, just a silly question.
Which solver (tutorial) is for the problem of heat transfer between fluid and solid?
Cheers
phsieh2005 December 13, 2012 16:06
chtMultiRegionSimpleFoam - steady state
chtMultiRegionFoam - transient
Pei-Ying
mxylondon December 14, 2012 09:50
Thanks!
But, in the tutorial for chtMultiRegionFoam>>multiRegionHeater, by typing 'chtMultiRegionFoam', why there is a FATAL ERROR names [Cannot find file ''points'' in directory ''bottomAir/polyMesh'' in times 0 down to constant...]?
Did I miss some thing?
Cheers!
phsieh2005 December 14, 2012 20:54
In the example case (say, multiRegionHeater), type ./Allrun to run the case. Study the Allrun script to learn how to run the case and study the case structure.
Good luck!
Pei-Ying
