Boundary conditions
Old   December 24, 2012, 03:08
Default Boundary conditions
zaynah K.
zaynah04 is on a distinguished road
Dear experienced Open foam user,
the learning of openfoam and ubuntu is done in a very slow process by me..
I have now successfully converted my gambit file to foam format and i have grasped most of the foam mode of use. EXCEPT Boundary conditions..
after converting my mesh to foam, i went to P and U folder to Modify bC but when i go also in constant/polymesh/boudary i found that all the parameters that u used ie s1 s1 v and p are exactly same, but i am confused in the P and U . can anyone help me please?
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0.0002 0 0);
boundaryField
wall-4
type fixedValue;
value uniform (0 0 0);
velocity-inlet-5
type fixedValue;
value uniform (1 0 0);
velocity-inlet-6
type fixedValue;
value uniform (0 3 0);
pressure-outlet-7
type zeroGradient;
wall-8
type fixedValue;
frontAndBackPlanes
type empty;
and for P
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall-4
type zeroGradient;
velocity-inlet-5
type zeroGradient;
velocity-inlet-6
type zeroGradient;
pressure-outlet-7
type fixedValue;
value uniform 0;
wall-8
type zeroGradient;
frontAndBackPlanes
type empty;
and in constant/polymesh/boundary
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
6
cylinder
type wall;
nFaces 90;
startFace 19215;
p
type patch;
nFaces 90;
startFace 19305;
s2
type symmetryPlane;
nFaces 90;
startFace 19395;
s1
type symmetryPlane;
nFaces 90;
startFace 19485;
v
type patch;
nFaces 90;
startFace 19575;
frontAndBackPlanes
type empty;
nFaces 19440;
startFace 19665;
zaynah04 is offline   Reply With Quote
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 05:37
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
