-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   lid driven cavity test case (http://www.cfd-online.com/Forums/openfoam/110884-lid-driven-cavity-test-case.html)
nsreddysrsit December 24, 2012 01:26
How to set BC's for lid driven cavity problem if i use rhoPisoFoam Solver for compressible flows.
thanks in advance
Ahmed Khattab December 24, 2012 04:14
Originally Posted by nsreddysrsit (Post 398848)
How to set BC's for lid driven cavity problem if i use PisoFoam Solver.
thanks in advance
i think you shouldn't. but may be there are some parameters you must add. you can see tutorial case on pisoFoam to know what you needd to chnage.
good luck :)
nsreddysrsit December 24, 2012 06:38
lid driven cavity with heated walls
which solver is suitable for heated plate lid driven cavity for compressible flows, and how to set BC's for the above problem.
thanks in advance
Ahmed Khattab December 24, 2012 07:30
icoFoam with heat transfer
thanks in advance
the situation is different now, you need to add heat transfer to the case, there is a modified icoFoam deals with you case.
please check this URL:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
i did it before and it worked well. :cool:
have a nice foaming
nsreddysrsit December 24, 2012 19:06
hi
thanks for the reply,
sorry for the incomplete problem description, here i am giving proper description,
the cavity is 2D, fluid is Air with T0 = 291.789, p0= 101.325 kpa is filled in this cavity. Re =100 for a Mach number of 0.001.
I have to solve the above problem with rhoPisoFoam or rhoSimple Foam. or any suggestions.
how to set BC's if i use rhoPisoFoam.
thanks in advance
Ahmed Khattab December 25, 2012 08:10
flow in or around cavity?
thanks in advance
do you mean that you want to study flow around the cavity?
i think so as you mentioned Mach number.
regards,
