-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   droplet motion on incline plane (http://www.cfd-online.com/Forums/openfoam/110895-droplet-motion-incline-plane.html)
IndrajitW December 24, 2012 09:18
Hi all,
I want to simulate droplet motion on inclined plane. Please guide me where can I find the relevant cases. I have done the dam break tutorial.
Regards,
Indrajit
Bernhard December 24, 2012 13:03
Ehm, you will have to set up te cases yourself. First make a mesh, then initiliaze the droplet (setFields or funkySetFields), change the direction of g in constant/g and run the simulation. Where are you stuck in this process?
IndrajitW December 24, 2012 14:21
I am stuck at initializing the droplet, using the funkysetfields .Also I wish to implement the dynamic contact angle model in OpenFoam. Please let me know where could i get a similar case so that I could edit and use it.
Regards,
Indrajit
liguifan February 10, 2013 16:37
Hello Bernhard,
I am new to the multiphase case and I want to simulate the the droplet case as well. For the droplet, do you suggestion I use some software like Gmsh to create a sphere or I can directly use set Fields or funkySetFields to create it?
Btw, in the openfoam wiki, the link provided is not working, so I am not sure where I can download the up-to-date version of funkySetfields?
Best regards,
James
Bernhard February 10, 2013 16:49
I would not suggest using the mesh to make your droplet, as it is necessary for the initial state as well. For funkySetField I am certain that you can select a region of cells based on an expression. Latest versions are now included in swak4Foam.
liguifan February 10, 2013 16:52
Thanks for the quick reply, do you mean I firstly use Gmsh to mesh a sphere and then use the funkySetfield to define it as the water?
Or I don't need to use Gmsh at all?
Kind regards,
James
Bernhard February 10, 2013 16:54
It depends on what type of solver you want to use of course. But if you stick to a volume of fluid solver (interFoam), then I would just mesh with blockMesh and define the droplet with funkySetFields (or maybe even regular setFields if possible, not sure about that)
liguifan February 10, 2013 17:07
Thanks again for that, I went to the funckySetFields on openwiki, I can tell it is powerful for the examples given, like the groovyBC for Boundary condition; however, I tried to download the 1.5 and 1.6 version, link seems to be not working anymore.
One another question is that:
I have build up a box with the leftwall, rightwall, lowerwall, frontwall, and backwall using Gmsh, and I use the setFields to create a sphere in the liquids, but the bubble burst before it rises to the surface of the water and the water leaks out from the leftWall Even I define the velocity of BC of all the walls with U=fixedValue {0 0 0}.
The boundary conditions are as follows
alpha1.org
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
leftWall
type zeroGradient;
rightWall
type zeroGradient;
lowerWall
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
frontWall
type zeroGradient;
backWall
type zeroGradient;
p_rgh
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
leftWall
type buoyantPressure;
value uniform 0;
rightWall
value uniform 0;
lowerWall
value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
frontWall
value uniform 0;
backWall
value uniform 0;
U
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
leftWall
type fixedValue;
value uniform (0 0 0);
rightWall
type fixedValue;
lowerWall
type fixedValue;
atmosphere
type pressureInletOutletVelocity;
frontWall
type fixedValue;
backWall
type fixedValue;
I appreciate that you can give me some hint.
Kind regards,
James
