please help me which solver is better for my application
Old   July 22, 2010, 05:29
Default please help me which solver is better for my application
usn
Ger_US is on a distinguished road
Hai everyone,
I am new to OpenFoam...my Geometry (Inlet Duct, constant Inlet Valve position, closed outlet valve and cylinder) is meshed in Icem...mesh size is approximately 5 millionen...now I would like to simulate in OpenFoam but I don't know which solver is suitable for my application...I am searching for compressible steady state Komega sst solver. I tried with rhoPisoFoam but it didn't work....please help me is there any other compressible steady state Komega sst solver available in OpenFoam...and one more thing I would like to give pressure-pressure boundary conditions at Inlet and Outlet
Inlet at Inlet Duct:
total pressure: 0 Pa
temperature: 298 k
Outlet at Cylinder Bottom:
static pressure: -5000 Pa
temperature: 299.5 k
Thank you in advance
Ger_US is offline   Reply With Quote
Old   July 22, 2010, 05:54
MSarkar
msarkar is on a distinguished road
Hi
You mentioned you want to use steady state compressible flow solver but you used rhoPisoFoam which is a transient solver. However, you can try rhoSimpleFoam that is steady state SIMPLE solver for laminar or turbulent RANS flow of compressible fluid.
Hope it will help you.
M. Sarkar
msarkar is offline   Reply With Quote
Old   July 23, 2010, 05:06
usn
Hi Sarkar,
thank you very much for your reply...ja I know about Piso just I tried to know is there any problem with my mesh...now I am trying with rhoSimpleFoam for sst...soon I give reply whether I succeed or not
thank you again
Old   July 26, 2010, 04:26
usn
Hi Sarkar
I tried with rhoSimple Foam...but not reached to my cfx results....here I am providing my data...please tell me if I am doing anything wrong
U:
INLET
type zeroGradient;
OUTLET
type zeroGradient;
WALL
type zeroGradient;
p:
INLET
//type fixedValue;
//value uniform 98038.6;
//type zeroGradient;
type totalPressure;
p0 uniform 1e5;
value uniform 1e5;
gamma 1.4;
psi psi;
//rho rho;
OUTLET
type fixedValue;
value uniform 95000;
WALL
type zeroGradient;
omega:
INLET
type fixedValue;
value uniform 2080.55;
OUTLET
type zeroGradient;
WALL
type zeroGradient;
k:
INLET
type fixedValue;
value uniform 16.977;
OUTLET
type zeroGradient;
WALL
type zeroGradient;
epsilon:
INLET
type fixedValue;
value uniform 3178.95;
OUTLET
type zeroGradient;
WALL
type zeroGradient;
RAS Properties: Turbulence Properties:
RASModel kOmegaSST; simulationType RASModel;
turbulence on;
printCoeffs on;
thermophysicalProperties:
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
mixture air 1 28.96 1004.4 0 1.831e-05 0.7142;
fvSchemes:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(U) Gauss linear;
grad(p) Gauss linear;
divSchemes
div(phi,U) Gauss upwind;
div((muEff*dev2(grad(U).T()))) Gauss linear;
div(phi,h) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,k) Gauss upwind;
div(phid,p) Gauss linear;
div(U,p) Gauss linear;
div(phiU,p) Gauss linear;
div(phi,R) Gauss upwind;
div(phi,omega) Gauss upwind;
div((rho*R)) Gauss linear;
div(R) Gauss linear;
div(U) Gauss linear;
laplacianSchemes
laplacian(muEff,U) Gauss linear corrected;
laplacian(mut,U) Gauss linear corrected;
laplacian(alphaEff,h) Gauss linear corrected;
laplacian((rho|A(U)),p) Gauss linear corrected;
laplacian((rho*rAU),p) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DomegaEff,omega) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(1,p) Gauss linear corrected;
laplacian((rho*(1|A(U))),p) Gauss linear corrected;
interpolationSchemes
default linear;
div(U,p) upwind phi;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
fvSolution:
rho
solver PCG;
preconditioner DIC;
tolerance 1e-05;
relTol 0;
p
solver GAMG;
tolerance 1e-08;
relTol 0.05;
smoother GaussSeidel;
cacheAgglomeration false; //off -> true
nCellsInCoarsestLevel 10; // 20 -> 10 Fehlermeldung damit behoben
agglomerator faceAreaPair;
mergeLevels 1;
maxIter 500;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
h
solver PBiCG;
tolerance 1e-06;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-05;
relTol 0;
k
solver smoothSolver;
nSweeps 2;
tolerance 1e-07;
relTol 0.1;
epsilon
nSweeps 2;
tolerance 1e-07;
relTol 0.1;
omega
nSweeps 2;
tolerance 1e-07;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
pMin pMin [ 1 -1 -2 0 0 0 0 ] 100;
relaxationFactors
p 0.1;
rho 0.05;
U 0.3;
k 0.05;
epsilon 0.05;
omega 0.05;
h 0.3;
R 0.05;
and I attached the results to this message as jpg files
please see my data and help me where I am doing wrong....I am new to OpenFoam and also new to CFD
thank you in advance
Old   July 26, 2010, 04:34
usn
Hi
and I forgot to tell you that the simulation diverged after some iterations...here is the result...
Time = 1299
DILUPBiCG: Solving for Ux, Initial residual = 0.103001, Final residual = 6.2714e-06, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 0.0729241, Final residual = 4.88299e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.0808816, Final residual = 3.54645e-06, No Iterations 3
DILUPBiCG: Solving for h, Initial residual = 0.478437, Final residual = 0.0172015, No Iterations 1
GAMG: Solving for p, Initial residual = 0.69215, Final residual = 0.0323442, No Iterations 15
time step continuity errors : sum local = 1241.23, global = 604.855, cumulative = 836.722
rho max/min : 179.449 -2205.68
bounding p, min: -3.68828e+09 max: 7.43339e+07 average: -1.19258e+07
smoothSolver: Solving for omega, Initial residual = 2.21321e-23, Final residual = 2.21321e-23, No Iterations 0
smoothSolver: Solving for k, Initial residual = 0.0534275, Final residual = 2.55456e-05, No Iterations 2
bounding k, min: -88298.8 max: 2479.51 average: 5.23806
ExecutionTime = 51147.7 s ClockTime = 51181 s
Time = 1300
DILUPBiCG: Solving for Ux, Initial residual = 0.0840612, Final residual = 1.05299e-06, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.0646994, Final residual = 4.51054e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.0725841, Final residual = 1.03022e-06, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 0.709417, Final residual = 0.0270025, No Iterations 1
[2]
[2]
[2] Maximum number of iterations exceeded#0 Foam::error:rintStack(Foam::Ostream&) in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 main in "/server/appl/Programme/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSimpleFoam"
#5 __libc_start_main in "/lib64/tls/libc.so.6"
#6 _start at ../sysdeps/x86_64/elf/start.S:116
[2]
[2]
[2] From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
[2] in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68.
[2]
FOAM parallel run aborting
[2]
MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 2 with PID 10612 on
node cn-12 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
please help me Sarkar or anyone please
Old   July 26, 2010, 09:29
Default Same Problem
Alexander
wise is on a distinguished road
Same Problem:
Time = 1.65e-05
Courant Number mean: 5.0346e-06 max: 11.2864
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 0.930813, Final residual = 5.81638e-06, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.937236, Final residual = 8.94623e-06, No Iterations 4
DILUPBiCG: Solving for Uz, Initial residual = 0.814971, Final residual = 3.0321e-06, No Iterations 4
DILUPBiCG: Solving for e, Initial residual = 0.805664, Final residual = 2.73097e-06, No Iterations 4
--> FOAM FATAL ERROR:
in file /home/opencfd/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam170/lib/linuxGccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::correct() in "/opt/openfoam170/lib/linuxGccDPOpt/libbasicThermophysicalModels.so"
in "/opt/openfoam170/applications/bin/linuxGccDPOpt/sonicFoam"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Why?
wise is offline   Reply With Quote
Old   July 27, 2010, 03:14
usn
Hi everyone,
if anyone knows the above problem....please help me
Old   January 8, 2013, 04:16
immortality's Avatar
Ehsan
immortality is on a distinguished road
i have same error message as alexander has had.will it be solved if i make mesh finer?or its irrelevant?
immortality is offline   Reply With Quote
Old   January 8, 2013, 12:29
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
The issue is that the extraction of Temperature from enthalpy is failing. Basically we can't find a temperature that makes sense for the enthalpy. I would recommend looking at your temperature field at the few timesteps before the crash. This will give you better information as to what is going on.
This type of error is difficult to diagnose over the Forum as they are case specific, and is subject to trial-and-error.
mturcios777 is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Solver dirtyness Programmer Main CFD Forum 1 June 20, 2008 08:07
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
User Solver in FoamX with a new field variable vvqf OpenFOAM Pre-Processing 2 October 28, 2005 20:24
