Home > Forums > OpenFOAM
Does interFoam consider the inter-phase momentum transfer?
Like Tree6Likes
  • 3 Post By kwardle
  • 3 Post By ziad
Old   January 9, 2013, 23:06
Default Does interFoam consider the inter-phase momentum transfer?
Jianye Xia
bioexplore is on a distinguished road
Can anybody tell me does the interphase drag force considered in interFoam? And what the difference between bubbleFoam and interFoam?
Thanks!
Jianye
bioexplore is offline   Reply With Quote
Old   January 10, 2013, 06:17
Andrea
Andrea1984 is on a distinguished road
Hi Jianye,
you can find the interFoam formulation in the Henrik Rusche's Ph.D. thesis.
Andrea
Andrea1984 is offline   Reply With Quote
Old   January 10, 2013, 15:53
Kent Wardle
kwardle is on a distinguished road
No. There is one velocity field shared by all phases in interFoam and it's derviatives (multiphaseInterFoam). bubbleFoam (and twoPhaseEulerFoam) uses Euler-Euler so each phase has it's own velocity field and inter-phase momentum transfer is supplied via drag formulations. A newer solver, multiphaseEulerFoam, is unique in that it does Euler-Euler for an arbitrary number of phases (with inter-phase drag), but it can also impose a sharp interface a la interFoam on any phase pairs. Hope this is useful info.
ziad, bioexplore and Andrea1984 like this.
kwardle is offline   Reply With Quote
Old   January 10, 2013, 22:14
Jianye Xia
Thanks Andrea!
Originally Posted by Andrea1984 View Post
Hi Jianye,
Andrea
But I think Henrik Rusche's Ph.D thesis dealing with bubbleFoam but not interFoam. Is this right? Can anyone know this give some explaination?
Old   January 10, 2013, 22:21
Jianye Xia
Thanks Kwardle!
You make it more clear!
What's my understanding is that (If I was wrong, please correct it!):
Because there is one share velocity field in interFoam, so there is no interphase momentum item derived in the UEqn, and the interface between liquid and gas is davanced by solving the alpha equation?
For bubbleFoam, the derived UEqns for each phase have the interphase momentum item, so when solving each phase's UEqn the interphase momentum item should also be given?
Is this correct?
Old   January 13, 2013, 17:10
Ziad Boutanios
ziad is on a distinguished road
interFoam is a Volume of Fluid solver so it solves one set of mixture Navier-Stokes equations with a volume fraction scalar transport equation that determines which phase you're dealing with. It does not account for interphase momentum transport because it is simply not part of the VOF mixture formulation.
It is described in Onno Ubink's PhD thesis, and definitely not Henrik Rusche's, as pointed out by kwardle. Check out equations 2.14 and 2.15 in Onno's thesis which can be found there http://powerlab.fsb.hr/ped/kturbo/Op...oUbbinkPhD.pdf
In bubbleFoam (and twoPhaseEulerFoam) you solve a full set of NS equations for each phase and couple them with the momentum coupling term which includes drag, lift and virtual mass. Turbulence is done with k-epsilon on the mixture.
bioexplore, vbnhfylbh and rapierrz like this.
ziad is offline   Reply With Quote
Old   January 13, 2013, 20:48
Jianye Xia
Hi, Ziad, Thanks very much for your clearly explaination, It makes me more clear about the difference between interFoam and bubbleFoam.
Old   January 13, 2013, 20:51
Ziad Boutanios
You're quite welcome.
Old   January 28, 2013, 22:44
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Some clarifications,
1. Henrik Rusche's thesis deals both with VOF and Euler-Euler
2. VOF can be derived from Euler-Euler via the Mixture Model, giving which I call the Weller-VOF method, this explains why interFoam retains the relative velocity term in the alpha Eqn. and the necessity to go from volumetric flux formulation to mass flux formulation assembling the rhoPhi field. This is a key concept to understand the interFoam code.
3. As the guys told, the velocity is treated as a only one field in the momentum equations so that the interphase momentum exchange term vanishes (its expresion is \propto V_{pq}\otimes V_{pq}, where V_{pq} is the relative velocity between phases p and q).
I give a full explanation of these issues in my PhD thesis which is in review, it will be available for the community by the end of March, 2013.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Thread Tools
Trackbacks are On
Implementation of the phase momentum equation in BubbleFoam Anne Severt OpenFOAM 1 November 27, 2013 05:15
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
Conservation equations, momentum transfer forces Luke F Main CFD Forum 1 April 25, 2008 16:49
Which Code is Best for Two Phase, Heat Transfer earlc Main CFD Forum 0 September 23, 2005 20:26
