Looking for "Derivation [...] of the conditionally averaged two-phase flow equations" |
November 12, 2015, 06:06 |
X Meng
Rep Power: 13 |
Dear Foamers,
Does anyone have refrence paper <Derivation, modelling and solution of the conditionally averaged two-phase flow equations> form Mr HG Weller? Great thanks!!! Regards |
November 22, 2015, 08:21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: Have you tried the contact form at CFD Direct? http://cfd.direct/contact/
It's where Henry Weller works at: http://cfd.direct/about/ |
October 18, 2016, 03:49 |
Martin Aunskjaer
Rep Power: 17 |
I have seen this report being requested a number of times. While it appears unavailable, the process of conditional averaging is well described in works of other authors. Particularly lucid treatments can be found in [1, ch. 2] and [2, ch.1.6 + appendix A]. There is also a report by Weller [3] in which he treats this subject. The idea of conditional averaging is based on the work of Dopazo [4] for turbulent flows.
[1] Holger Marschall, “Towards the Numerical Simulation of Multi-Scale Two-Phase Flows”, PhD thesis, München, 2011 https://mediatum.ub.tum.de/doc/1080878/1080878.pdf [2] David Paul Hill, ”The Computer Simulation of Dispersed Two-phase Flows”, PhD thesis, London, 1998 http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/DavidHillPhD1998.pdf [3] H.G. Weller, “The Development of a New Flame Area Combustion Model Using Conditional Averaging”, Imperial College, London, 1993 http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.45.6303&rep=rep1&type=pdf [4] C. Dopazo, On conditional averages for intermittent turbulent flows, Journal of Fluid Mechanics 81 (1977) 433-438. |
October 19, 2016, 00:15 |
Cyprien
Rep Power: 18 |
You may also look at this short note on the derivation of continuity equation for VOF with mass transfer
or look at this Master thesis, Chap3 These derivations are based on the method of volume averaging (integration on volume, including the boundary effects as body forces). Cheers |
Display Modes | |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
2 Phase Flow, Gas Jet into Water Simulation Method | im_lenny | OpenFOAM | 3 | May 4, 2017 04:20 |
Divergence in Two phase flow in impeller for Cavitation | joshghoun | Fluent Multiphase | 2 | November 5, 2014 10:33 |
multi phase flow with chemical reactions in one phase | Habibfateh | OpenFOAM Programming & Development | 0 | February 10, 2014 08:33 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 03:52 |
