fuction for ddt(n) which n is normal surface vector
Old   April 11, 2011, 06:34
Default fuction for ddt(n) which n is normal surface vector
Mohammad.R.Shetab
mrshb4 is on a distinguished road
Dear Foamers
I'm writing an acoustic code for dynamic mesh case in a centrifugal fan. I use turbDyMFoam with movingWallVelocity BC at blades.
In one of the terms of this code, ddt(n) is needed, witch n is the normal vector of the blade surfaces that move around. I know the functions for normal vector of the patches but for its time derivative I don't know how to calculate them.
Another question is, Is there any function that could calculate velocity of the faces of the blade (which use dynamic mesh dict and movingWallvelocity) ?!
Thank you
Mohammadreza Shetab
mrshb4 is offline   Reply With Quote
Old   October 5, 2016, 08:14
Sergej
tonky is on a distinguished road
Hello Foamers and Mohammadreza,
I have the same problem now and read many topics here in cfd-online.com, but did not found any solution. I hope for a hint, because my tryings were not successfully.
So how to calculate the surface normal velocity of a free design surface?
For example on the rotor in the picture which is uploaded here, the rotation vectors are shown. So the normal surface velocity on the x-y plane must be zero, because there is no moving in the direction of the surface normal.
tonky is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
out normal vector ztdep Main CFD Forum 0 September 14, 2008 08:08
Normal Vector on Curved Surfaces Karl FLUENT 0 July 2, 2001 04:35
