Poiseuille flow: strange behaviour
Old   February 15, 2013, 07:23
Default Poiseuille flow: strange behaviour
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I am trying to simulate a Poiseuille-flow. It is a very simple problem, but I notice a strange behaviour. Everything seems to be ok. Actually, if you analyze the attached picture, you can see that Uz presents a strange `red cell' (i.e. a value pretty high) in the cell between the upper wall and the inlet. As far as the BC are concerned, here are the files for P and U:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    wall
        type            zeroGradient;
    xwall													// facce perpendicolari a x
        type			empty;
    inlet1
        type            zeroGradient;
    outlet
        type            fixedValue;
        value			uniform 0;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    wall
        type            	fixedValue;
        value			uniform (0 0 0);
    inlet1
	type			groovyBC;
	value			uniform (0 1 0);
	variables		"Vm=0.5;xp=pos().x;zp=pos().z;hx=max(xp);hz=max(zp);a=-8*Vm/(hz*hz);b=2*Vm;R=hz/2;";
	fractionExpression	"1";
	valueExpression		"vector (0, a*((zp-R)*(zp-R))+b, 0)";
    outlet
    type		zeroGradient;
        type			empty;
Also, I am running simpleFoam.
Why this happens? Could this cell be `dangerous' for the whole solution?
Any idea?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   February 15, 2013, 10:39
Bernhard
Bernhard is on a distinguished road
This is completely wrong.
What solver are you using?
Do you by any chance have a pRef defined in system/fvSolution?
Bernhard is offline   Reply With Quote
Old   February 15, 2013, 10:45
Samuele Z
I know that it is completely wrong.
I am using simpleFoam and I do not have pRefCell defined in the fvSolution file.
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-5;
        relTol           0.1;
        smoother         GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels      1;
    U
        solver           smoothSolver;
        tolerance        1e-5;
        relTol           0.1;
        nSweeps          1;
SIMPLE
    nNonOrthogonalCorrectors 0;
	residualControl
        p           1e-5;
        U           1e-5;
potentialFlow
    nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
cache
    grad(U);
Old   February 15, 2013, 10:53
Bernhard
You are looking at a unconverged solution. You now look at the second iteration. Note that deltaT does not mean time in the simple*Foam solvers. Set deltaT to 1, endTime to 1000 (thus 1000 iterations), and look at the last saved step to see what has changed. Check out the simpleFoam source code to see what is going on (loop-wise).
Did your log-file end with a statement "Solution has converged", or something like that?
Old   February 15, 2013, 11:02
Samuele Z
That was not a converged solution (but the same happens for the converged one) and my DeltaT is already set to 1. You see Time 2000 and `snapshot' 2 because I save the solution each 1000 steps.
Also, adding a pRef in the fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-5;
        relTol           0.1;
        nPreSweeps       0;
        nPostSweeps      2;
        mergeLevels      1;
    U
        tolerance        1e-5;
        relTol           0.1;
        nSweeps          1;
SIMPLE
	pRefCell 	14436;
	pRefValue	0;
	residualControl
        p           1e-5;
        U           1e-5;
potentialFlow
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
cache
    grad(U);
I get the same behaviour (see the picture attached).
The picture shows the solution after 100 iterations, but the same happens for the converged solution (I'll post it soon).
Ideas?
Old   February 15, 2013, 11:05
Bernhard
You definitely don't need the pRefCell (it will also not be used hopefully). Can you show a snippet of your logfile? I think a lot can be gained in your fvSolutions.
Old   February 17, 2013, 03:31
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
dear samuele,
could you please attach your entire case, i faced same problems before but i simulated this case in tube and used icoFoam. i think the problem doesn't relate to refP but to boundary conditions. you may try make outlet BCs as inletOutlet.
thanks and good luck
Ahmed Khattab is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Urgent Help !!!Strange reverse flow in naca0012 problem parvez2683 FLUENT 5 May 20, 2013 09:25
strange behaviour of the one-equation SGS model cfdmarkus OpenFOAM Running, Solving & CFD 18 August 14, 2009 05:33
Poiseuille flow (flow in a pipe) in SOLA-VOF. Parabolic distribution of velocities. Anton Main CFD Forum 9 April 29, 2009 10:31
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
