Home > Forums > OpenFOAM
Forced convection with OF
Old   January 31, 2013, 11:35
Default Forced convection with OF
Andrea
Andrea1984 is on a distinguished road
I would like to simulate a forced convection heat transfer problem using OF. The flow is incompressible and turbulent.
Any hints for the choose of the right solver, BCs and other settings are welcome.
Thanks,
Andrea
Andrea1984 is offline   Reply With Quote
Old   January 31, 2013, 15:28
romant's Avatar
Roman Thiele
romant is on a distinguished road
Originally Posted by Andrea1984 View Post
Thanks,
Andrea
For heat transfer problems with incompressible flow, take a look at bouyantBoussinesqSimpleFoam and buoyantBoussinesqPimpleFoam, for steady state and transient calculations respectively. There are a couple of tutorials included in OpenFOAM
~roman
romant is offline   Reply With Quote
Old   February 1, 2013, 07:55
Andrea
Hi Roman,
thank you for your reply.
These solvers are suitable only for buoyant flows, or are still valid in case of forced convection?
Old   February 1, 2013, 08:33
romant's Avatar
Roman Thiele
yes, they are also valid for forced convection. The "buoyant" part of the name just states that they use the boussinesq approximation for buoyancy, where small changes in density are modeled through a temperature difference. but other than that the density is constant.
~roman
Old   February 1, 2013, 10:18
Andrea
Ok, their names are a little bit misleading.
I'll have a look to the source code and run some test cases.
Thank you for the infos.
Andrea
Old   February 1, 2013, 10:21
romant's Avatar
Roman Thiele
Hej,
it doesn't really matter that the buoyant part this is in the solver, since in forced convection your change in density and the buoyancy forces associated with it will be minimal (the flow will not be affected by it). Therefore, the solvers can be used for forced convection and for natural convection.
~roman
Old   April 4, 2013, 14:49
Jubayer
Location: The University of Western Ontario, London, Ontario
cm_jubayer is on a distinguished road
Hi Andrea,
I am also simulating forced convection over a solar panel in the atmospheric boundary layer. I am using buoyantBoussinesqPimpleFoam. Based on nOuterCorrectors you can switch between Pimple and Piso. Also, I am using 0 gravity which makes p and p_rgh same. However, I am facing bounding problem with omega specially (using SST k omega), trying different limited schemes, no luck yet.
But, to test the solver, I ran a simulation with forced convection over a flat plate with high Re and found a good match with the turbulent boundary layer correlation in theory. Also, I think to solve forced convection correctly, boundary layer has to be resolved completely (y+<1) without using wall functions.
Jubayer
cm_jubayer is offline   Reply With Quote
Old   April 4, 2013, 15:03
Andrea
Hi Jubayer,
Unfortunately I had to stop my testing with OF in forced convection because right now I'm pretty busy with other undertakings; however I would be glad if you can attach your convection over a flat plate case.
Thanks in advance,
Andrea
Old   April 4, 2013, 15:20
Jubayer
You can download it from here
Jubayer
Old   April 5, 2013, 04:53
Andrea
Thank you so much
Andrea
Old   January 14, 2014, 13:10
Pritanshu Ranjan
aamo is on a distinguished road
Jubayer
Hi Jubayer, I think you have removed the files from your dropbox. could u please upload it again.
aamo is offline   Reply With Quote
Old   January 14, 2014, 13:35
Jubayer
Here is the link again:
https://dl.dropboxusercontent.com/u/...atPlate.tar.gz
Jubayer
Old   May 11, 2015, 11:47
Smile Forced convection with OF
  #13
Sandeep Rapol
sandeeprapol is on a distinguished road
I would like to simulate a forced convection heat transfer problem using OpenFOAM. The flow is compressible and turbulent. Which solver is suitable?
Thanks & Regards,
Sandeep Rapol
sandeeprapol is offline   Reply With Quote
Old   May 12, 2015, 03:53
romant's Avatar
Roman Thiele
Originally Posted by sandeeprapol View Post
Thanks & Regards,
Sandeep Rapol
Take a look at this site http://cfd.direct/openfoam/user-guid.../#x13-890003.5
You probably want to take one of the solvers from the compressible family. They are nicely explained there and you should think about whatelse your solver should do. Steady state or transient, supersonic or subsonic flow, do you want to include buoyancy at a later stage (then take a look at the heat transfer solver family).
It shouldn't be too hard to find the right solver for your purpose.
~roman
Old   May 13, 2015, 09:42
roadRunner is on a distinguished road
Setting gravity vector to zero should disable all buoyancy effects and enable pure forced convection.
beep-beep
roadRunner is offline   Reply With Quote
Thread Tools
Trackbacks are On
thermo settings for natural and forced convection braennstroem OpenFOAM Running, Solving & CFD 3 May 1, 2011 12:33
Coupled vs Seg - Natural vs. Forced Convection Alex CD-adapco 5 December 12, 2007 05:58
help please with forced convection lucia FLUENT 3 September 7, 2007 16:59
heat convection in a forced fluid Daniele Main CFD Forum 0 December 20, 2005 09:09
giving natural and forced convection bc's Venu Gopal FLUENT 0 August 29, 2004 10:59
