OpenFOAM- Low Mach Number Formulation for Combustion
Like Tree14Likes
  • 1 Post By hz283
  • 4 Post By kalle
  • 2 Post By piccinini
  • 1 Post By tmu
  • 1 Post By atulkjoy
  • 1 Post By ab2484
  • 4 Post By malaboss
Old   February 5, 2013, 05:50
Default OpenFOAM- Low Mach Number Formulation for Combustion
tmu
Anderson
tmu is on a distinguished road
Hi Dear Friends,
I want to know if anybody tried to simulate combustion using low mach number model in OpenFOAM.
I would be appreciate if anybody can help me
Are there any solver for modeling reacting flow with Low mach number Formulation?
tmu is offline   Reply With Quote
Old   February 5, 2013, 17:44
hz283 is on a distinguished road
fireFoam 1.6.0 is the one you want--Low ma number. Others are not as far as I know. They are incompressible or compressible, but obtaining the Low ma number solver only needs very small modification based on the compressible codes.
tmu likes this.
hz283 is offline   Reply With Quote
Old   February 6, 2013, 01:29
tmu
Anderson
Thank you for response
I want to simulate combustion in tube (3D) and channel (2D).
and I think reactingFOAM is a suitable solver
but I dont know How to change this solver for Low mach number flow.
Can you give me some help that I can develop this solver?
thank you so much
Old   February 6, 2013, 02:24
Karl-Johan Nogenmyr
kalle is on a distinguished road
If your thermodynamic pressure can be considered constant throughout the simulation (i.e. not a piston engine), you'll find what you need to change here:
http://web.student.chalmers.se/group...SlidesOFW5.pdf
This was for OF 1.5, but the change of reactingfoam-2.1 is straight forward.
The solver works good, and has generated a number of papers:
Duwig, Christophe, Sébastien Ducruix, and Denis Veynante. "Studying the Stabilization Dynamics of Swirling Partially Premixed Flames by Proper Orthogonal Decomposition." Journal of Engineering for Gas Turbines and Power 134 (2012): 101501.
Duwig, Christophe, et al. "Large Eddy Simulations of a piloted lean premix jet flame using finite-rate chemistry." Combustion Theory and Modelling 15.4 (2011): 537-568.
K
kalle is offline   Reply With Quote
Old   February 6, 2013, 20:19
piccinini is on a distinguished road
Hello.
You may see if it helps:
http://code.google.com/p/lowmachspra...lowmachSolver/
I've adapted dieselFoam 1.7 for a spray simulation in low Mach number. "pd" is the hydrodynamic pressure and "p" is the thermodynamic one. I considered the case of "p" being constant only.
tmu and Dreoasteh like this.
piccinini is offline   Reply With Quote
Old   February 9, 2013, 12:15
tmu
Anderson
Thank you for your response.
Old   February 27, 2013, 13:12
Default Boundary Condition- Low mach number in combustion
tmu
Anderson
Hi Friends
I am working on simulation combustion in channel. I change reactingfoam for solving low mach formulation. now I have some question about p.
1. I have a open system, and I set preff = 101325 (1 atm), Is it true?
2. for pd (pdynamics), I set
Inlet boundary : zero gradient
outlet boundary: constant 101235
but I think this is wrong because pd is calculated between 101325 , 101225
and according relation P=Pd+Preff so P is 2 atm
Whereas in reference are said Pd<<preff
which boundary condition must I use for pdynamic?
Initial condition for pd is important?
thanks a lot
ozgunoglu likes this.
Old   October 1, 2017, 07:04
Cool Boundary Condition- Low mach number in combustion
Mehmet OZGUNOGLU
ozgunoglu is on a distinguished road
Hi Anderson,
I have the same problem for the initial and boundary conditions. Did you get any solution.
Thanks
ozgunoglu is offline   Reply With Quote
Old   October 1, 2017, 13:53
Default Low Mach Formulation
Ayush
upadhyay.1 is on a distinguished road
Hi Friends,
I have to develop a low Mach solver as my bachelor's project to simulate combustion of Sandia Flame D.
1.) I can't completely understand what is thermodynamic and dynamic pressures.
What I get thermodynamic is used in an equation of state while dynamic pressure is used in pressure equation. Right? and How we actually get this division of pressures?
2.) Is simpeFoam is a low-mach solver?
3.) If yes can we add an equation of state to get the low Mach solver along with other equation?
upadhyay.1 is offline   Reply With Quote
Old   October 1, 2017, 22:56
Atul Kumar
Location: National Centre for Combustion Research and Development
atulkjoy is on a distinguished road
Any where you don't solve density much more dependent on pressure change like rho/p is low Mach number solver you can see fireFoam and reactingFoam solvers based on psi n rho model also Piso n pimple formulation
Sent from my Lenovo K50a40 using CFD Online Forum mobile app
atulkjoy is offline   Reply With Quote
Old   October 2, 2017, 03:30
Ayush
Thank you Atul for the reply!
Could you please explain what do you mean by density much more dependent on pressure change?
Old   October 3, 2017, 01:41
Atul Kumar
Like supersonic flows where Mac h no is greater than 1 and effects of compressiblility are well seen in pressure while in low MACh no solver you don't have density coupled pressure solution n pressure is coupled with velocity
Saeng Kinley likes this.
Old   October 16, 2017, 07:28
Andrea
ab2484 is on a distinguished road
Hello everyone,
I'm having the same problems. I need to develop a Low-Mach version of reactingFoam 4.x, so I look forward to read some useful advices.
I had a look at the solver developed by Mr. Nogenmyr, but I still can't understand everything.
Thanks
atulkjoy likes this.
ab2484 is offline   Reply With Quote
Old   December 13, 2017, 11:12
Malik
malaboss is on a distinguished road
Hello all,
I have recently been developing a solver for this exact purpose: low-Mach number solver for variable density flows. This is oriented towards combustion applications, but can also be applied to other contexts. The solver was also designed to minimize kinetic energy dissipation which is critical for Large eddy simulations (LES) and Direct Numerical Simulations (DNS).
Extensive verification and validation is provided in the paper. We have been using it successfully for other purposes like soot production, spray flames and ignition problems.
The paper can be found here https://www.sciencedirect.com/scienc...45793017304280
There is also a version available on arXiv if you don't have access to the journal.
https://arxiv.org/abs/1705.04777
I hope it will help some of you !
Malik
malaboss is offline   Reply With Quote
Old   April 16, 2024, 22:00
bany
bany is on a distinguished road
Originally Posted by malaboss View Post
Hello all,
Malik
Thanks for your nice work. Can you share your low-Mach number solver? And what is the difference between reactingLMFoam (https://github.com/nogenmyr/reactingLMFoam).
My e-mail:banyang@tju.edu.cn
Thanks a lot.
bany is offline   Reply With Quote
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
pre-conditioning for low mach number compressible flow solver Shenren_CN Main CFD Forum 0 April 29, 2011 21:07
TVD scheme at low Mach number Axel Rohde Main CFD Forum 5 August 6, 1999 02:01
how calculate the density in low mach number? Juhee Lee Main CFD Forum 1 July 31, 1999 15:26
