NACA0012 with rhoCentralFoam
Old   May 1, 2011, 09:33
Default NACA0012 with rhoCentralFoam
Praveen. C
praveen is on a distinguished road
I am having some problem with a NACA0012 test case using rhoCentralFoam. The freestream mach is 0.75 and there is a shock. I have attached some pictures. There is something wrong with the bcs.
Some of the input options are listed below. Other input files are same as here
http://gfoam.svn.sourceforge.net/vie...12_7k_M075_a2/
Hope somebody can point out the mistakes.
0/p
internalField   uniform 85418.9;
boundaryField
    inlet-outlet
        type            fixedValue;
        value           uniform 85418.9;
    body
        //type            slip;
        type            zeroGradient;
    defaultFaces
        type            empty;
0/T
internalField   uniform 260;
boundaryField
    inlet-outlet
        type            fixedValue;
        value           uniform 260;
    body
        //type            slip;
        type            zeroGradient;
    defaultFaces
        type            empty;
0/U
internalField   uniform (242.284 8.46075 0);
boundaryField
    inlet-outlet
        type            fixedValue;
        value           uniform (242.284 8.46075 0);
    body
        type            slip;
    defaultFaces
        type            empty;
constant/thermophysicalProperties
thermoType      ePsiThermo<pureMixture<constTransport<specieThermo<eConstThermo<perfectGas>>>>>;
mixture         air 1 28.965 717.625 0 0 0.72;
praveen is offline   Reply With Quote
Old   May 1, 2011, 14:32
Exclamation
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
hi praveen,
Is the solution converges well and where can i really see that you used the rhoCentralFoam for your problem.
taxalian is offline   Reply With Quote
Old   May 1, 2011, 22:13
Praveen. C
Everything in the above link remains same for rhoCentralFoam except you have to change to
fluxScheme Kurganov; // or Tadmor
in system/fvSchemes. The files can be downloaded here
http://gfoam.svn.sourceforge.net/vie...5_a2/?view=tar
Old   June 3, 2011, 05:07
NAVEEN.K.M
naveen is on a distinguished road
hi praveen,
I am also trying for different airfoil simulation using rhoCentralFoam using different boundary condition at mach no=0.7. even i am also getting same error wat u r getting on airfoil surface for unstructured grid. But when i solved for structured grid (same airfoil wat i used for unstructured) i am getting perfect solution using rhoCentralFoam for C Grid without any disturbances on airfoil surface. Could you please tell me what s da solution for this type of problem, if u have solved.....
----Regards---------
NAVEEN.K.M
NAL
BANGALORE
naveen is offline   Reply With Quote
Old   June 3, 2011, 05:20
Praveen. C
I dont know whats the problem. I too got proper result with structured grid for naca case.
Old   June 3, 2011, 05:27
NAVEEN.K.M
OK....letś try some other way....can u give me your mail id....
NAVEEN.K.M
Old   June 8, 2011, 06:01
NAVEEN.K.M
hi praveen,
I got the proper results for airfoil using rhoCentralFoam for unstructured grid same as structured grid.
Regards
NAVEEN
Old   July 28, 2011, 12:00
TCH
Solarberiden is on a distinguished road
Hi guys, I encountered the same problem, could you please tell me how do you solve the problems on unstructured grid? Thanks a lot!~
Solarberiden is offline   Reply With Quote
Old   July 28, 2011, 12:42
Praveen. C
See http://www.cfd-online.com/Forums/ope...tml#post317918
Old   July 28, 2011, 21:31
venkat
venkataramana is on a distinguished road
can anybody provide details about preconditioning for the above solver for Mach number approaching zero.
thanks in advance,
Regards.
venkataramana is offline   Reply With Quote
Old   July 29, 2011, 00:36
Default for the mach number approaching to zero
  #11
TCH
thanks in advance,
Regards.
The above solver is naturaly a density based solver, so for the low Re number or Mach number problems, the problem won't be appropriate as far as I know, you could have a go with the pressure based solver like the prevails philosyphy which is used by most of the OpenFOAM solvers, PISO or SIMPLE family solvers.
regrads.
TCH
Old   July 29, 2011, 03:49
Default hi
  #12
venkat
solvers for compressible flows always has Mach number is greater than that of incompressible flows, using preconditioning we can use compressible flow solvers for solving incompressible N-S equations ( having Mach Number nearer to zero)
can anybody provide details about the code to implement in openFoam.
here I am attaching the link which contains the details about the method.
http://openfoamwiki.net/index.php/TestLucaG.
thanks in advance
regards.
Old   December 7, 2011, 22:49
Daniel
dancfd is on a distinguished road
Hello all,
I am trying to simulate a NACA 0012 airfoil in transonic flow. I believe that rhoCentralFoam would be the best solver for the compressible & transient simulations. However, I have not used a density-based solver before and I am struggling with a few issues:
1. What is the best way to check for convergence? When using simpleFoam, I plotted Ux_0 and p_0 residuals. In rhoCentralFoam, there is no p_0 residual (obviously) and the rho_0 residual is 0 from start to finish.
2. Here is what a typical timestep looks like in the log. I find it strange that all of the rho equations have 0 residual and 0 iterations. Any advice?
Mean and max Courant Numbers = 0.00853124 0.92921
deltaT = 4.19687e-07
Time = 8.52996e-07
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Ux, Initial residual = 3.21903e-06, Final residual = 2.88895e-09, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 2.167e-06, Final residual = 5.51926e-09, No Iterations 2
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for e, Initial residual = 5.09557e-06, Final residual = 1.47595e-08, No Iterations 2
smoothSolver:  Solving for omega, Initial residual = 3.91917e-06, Final residual = 3.3493e-10, No Iterations 2
bounding omega, min: -6231.35 max: 239456 average: 1107.8
smoothSolver:  Solving for k, Initial residual = 0.00250408, Final residual = 1.13916e-08, No Iterations 2
ExecutionTime = 0.28 s  ClockTime = 0 s
3. My simulation produced results that compared well to experiment in simpleFoam, however the Cp plot is a mess in rhoCentralFoam (both plots attached). Any ideas?
Thank you for any suggestions,
Dan
File Type: jpg cp_steady-static-rhocentral-m3-a13-r6.jpg (32.1 KB, 139 views)
File Type: jpg cp_-cases-steady-static-redo-forces-m3-a13-r6.jpg (28.8 KB, 113 views)
dancfd is offline   Reply With Quote
Old   December 12, 2012, 03:02
Default same question for zero density
  #14
Farshad
Farshad_Noravesh is on a distinguished road
Is there anybody who can help us with this question because many good people have asked it and no one has ever replied properly.
Kind Regards,
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   December 12, 2012, 03:16
Praveen. C
Have you seen this post
http://www.cfd-online.com/Forums/ope...ible-code.html
Old   December 12, 2012, 03:33
Default how about kurganov-tadmor or AUSM+?
  #16
Farshad
I read that and he mentioned that: "The obliqueshock and forwardstep cases run fine but there is some problem with the naca case. The case runs but the solution has strange behaviour near airfoil surface "
So i think the airfoil is a problem but why? The other problem is that the kurganov-tadmor or any other flux scheme is not available.
Kind Regards,
Farshad
Old   July 11, 2013, 08:29
Default naca0012 rhoCentralFoam instabilities
  #17
Johan
JohanAdam is on a distinguished road
Using Vuorinen's slides on "Compressible Runge-Kutta 4 LES-Solver to OpenFOAM", I implemented RK in rhoCentralFoam.
This seems to provide a notable improvement in removing those numerical instabilities. I am still using vanLeer in fvScheme and not gamma.
Regards
Johan
JohanAdam is offline   Reply With Quote
Old   July 5, 2018, 05:49
K
mkhm is on a distinguished road
Hi Daniel,
Did you find any answer to your question about convergence criteria for rhoCentralFoam ?
mkhm is offline   Reply With Quote
rhoCentralFoam with totalPressure/totalTemperature at inlet of subsonic channel deepblue17 OpenFOAM Running, Solving & CFD 5 February 11, 2013 02:42
Always crash when solve a C-D nozzle flow field using rhoCentralFoam hawklion OpenFOAM Running, Solving & CFD 0 March 9, 2011 06:13
NACA0012 Data as a function of Re for a VAWT model psd Main CFD Forum 1 July 31, 2009 22:04
NACA0012 experimental results. Kyung-Seok, Kim Main CFD Forum 0 March 13, 2006 05:46
I want NACA0012 simulation datas Santana Main CFD Forum 2 December 28, 2004 11:58
