heat conduction between different solids*
Old   February 10, 2013, 15:53
Question heat conduction between different solids*
Reno
jr33 is on a distinguished road
where one solid is surrounded by another solid.
I am solving heat conduction equation in each solid, so each solid has its own specific heat (c), density and thermal conductivity (k), thus we will solve two coupled time dependent temperature equations.
Does laplacianFoam will handle two regions? How about chtMultiRegionFoam.
any hint will be great?
jr33 is offline   Reply With Quote
Old   February 10, 2013, 21:09
doubtsincfd is on a distinguished road
Hi Reno,
Pure heat conduction in solid: laplacianFOAM
attaching of two regions depends on which software you are using for meshing
doubtsincfd is offline   Reply With Quote
Old   February 11, 2013, 11:36
Reno
Thanks Omkar for comments.
I am solving heat equation in each solid, so each solid has its own specific heat, density and thermal conductivity, thus we need to solve two coupled time dependent temperature equations. Does laplacianFoam will work here? How about chtMultiRegionFoam.
For meshing, I am using gmsh.
Old   February 12, 2013, 06:47
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
If you understand the chtMultiRegionSimpleFoam/multiRegionHeater tutorial you willbe able to set up your case.
niklas is offline   Reply With Quote
Old   February 12, 2013, 11:40
Smile
Reno
Thanks for comment, by now, I have figured the details of multiRegionHeater.
Currently I am stuck at meshing part: I mean: How to define interface between two regions? I use gmsh for meshing, I dont have blockMeshdict file.
Old   February 12, 2013, 12:51
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
An alternate method is to use elasticThermalSolidFoam in the solidMechanics branch of OpenFOAM-1.6-ext.
This solver allows for different properties in different regions, check out the bimaterialCase tutorial case for elasticSolidFoam.
elasticThermalSolidFoam solves the energy equation for temperature and then the momentum equation for displacements, obviously you could comment out all the displacement/stress stuff.
One advantage of this method is you just need one mesh with one region and no need to define an interface.
Just an option,
Best,
Philip
bigphil is offline   Reply With Quote
Old   February 12, 2013, 15:41
Reno
Thanks Philip, I downloaded the 1.6 extend version of openfoam from here: http://www.cfd-online.com/Forums/ope...t-problem.html
I did nt see " elasticSolidFoam" case or "solidMechanics" branch, is anyway I can find correct files.
Old   February 13, 2013, 05:29
bigphil's Avatar
Philip Cardiff
The solidMechanics code is a git branch on the OpenFOAM-1.6-ext git repository.
As the git repository is currently down, I have put ".tgz" of the solidMechanics solvers here.
I usually put the solidMechanics directory in the $FOAM_SOLVERS directory.
Best,
Philip
Old   February 14, 2013, 23:36
Thumbs up
Reno
Thanks Philip for the files.
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
Heat transfer, convection, radiation, conduction Sandra H. OpenFOAM 1 March 3, 2010 08:02
Conduction heat not balanced? Nepal CFX 7 May 31, 2005 11:51
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 08:22
