Home > Forums > OpenFOAM
Help me to solve foam fatal io error
Old   February 20, 2013, 02:27
Default Help me to solve foam fatal io error
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi Foamers,
I have been stuck with the Floating point exception error. After hacking old discussions about this error, i fixed "unset FOAM_SIGFPE", but still I am running into another Problem.
Error:
Time = 3nl [0 0 -1 0 0 0 0] 0.005626
DILUPBiCG: Solving for Ux: solution singularity
DILUPBiCG: Solving for Uy: solution singularity
DILUPBiCG: Solving for T: solution singularity
DICPCG: Solving for p: solution singularity
time step continuity errors : sum local = nan, global = nan, cumulative = nan
ExecutionTime = 0.33 s ClockTime = 0 snl [0 0 -1 0 0 0 0] 0.005626
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 3 the word 'nan'
file: /home/malli_reddy/OpenFOAM/malli_reddy-2.1.1/run/caseFile/system/data::solverPerformance::U at line 3.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 91.
FOAM exiting
Can any one help to solve this problem. Thanks in advance.
Regards
M Reddy
mmkr825 is offline   Reply With Quote
Old   February 20, 2013, 02:35
Bernhard
Bernhard is on a distinguished road
Floating point errors are often a sign for problems with your case or set-up. Ignoring the error does not make the prolem go away. You should try to find out what the problem is with your case.
Bernhard is offline   Reply With Quote
Old   February 20, 2013, 02:51
Hi Bernhard,
Thanks very much for quick reply. I am dealing with suspension flow (particles present in liquid media) and i prepared my solver by editing simpleFoam solver. I think my case and set up is OK, because when i give good initial guess for velocity (by running my case with another solver which is having only one liquid phase), the case is running very well and the results are accurate.
But when i run directly for suspension fluid with out giving good initial guess, i got the above mentioned error. Could you please tell me how to fix this problem.
Thanks
M Reddy.
Old   February 20, 2013, 02:54
Bernhard
My first guess would be, that somewhere in your own model, you divide by derivatives of velocities (strain rate or something). Without a good initialization, these derivatives are zero, causing the FPE. Of course when initializing with a real solution for the velocity field, these derivatives will be non-zero.
Old   February 20, 2013, 02:59
Hi Bernhard,
Your guess is correct. In my solver i am using strain rate term in my solver. Can you please help how to fix this without giving good initial guess. Should i change any fvschemes.
Thanks
M Reddy.
Old   February 20, 2013, 03:02
Bernhard
You cannot solve this via fvSchemes.
You have three options.
1. Start from a solved velocity field as initial guess. This is a perfectly fine approach.
2. Adopt your solve, such the flow field gets solved once, before the first iteration.
3. Where you divide by the strain rate, at a very small number. 1/1e-20 is fine, while 1/0 is not.
Old   February 20, 2013, 03:13
Hi Bernhard,
In my solver i have already added a small non-local term(a small constant) to local shear rate. Actually there are two models which gives the flow Physics of suspension fluid. For the model-1 your approach is working fine, but for model-2 it is not working. Even though the good initial guess in velocity has no effect.
Should i add anything to .bashrc to ignore such operation (divide by zero).
Thanks
m Reddy
Old   February 20, 2013, 03:31
Bernhard
Adjusting your .bashrc will certainly not be a solution to everything.
You should give more details on the models to see how the problem can be solved. You can easily find out which line is giving you the error (if not by the error itself, then by the infamous 'Info << "Foo 1" << endl;')
Old   February 20, 2013, 05:34
Hi Bernhard,
Thank you Very much for your kindness. I am attaching the links for the solver and case file.
Solver : https://www.dropbox.com/s/tm8i4y2u0a...M25Foam.tar.gz
Casefile: https://www.dropbox.com/s/rxro15ga6v...aseFile.tar.gz
My case is simple 2D rectangular pipe. Can you suggest me any tutorial to fix this problem.
Thanks
M Reddy
Old   February 20, 2013, 07:52
Bernhard
Maybe you can paste relevant pieces of the code here as well? Just a few line, that would make things easier.
Old   February 20, 2013, 08:54
Hi Bernhard,
very much thanks for your valuable time. In my solver, totally there are three fields (U, p and T).
Momentum Equation:
tmp<fvVectorMatrix> UEqn
      - fvm::laplacian(2*nu*ns, U)
      + fvc::div(Epnn1)
    UEqn().relax();
    sources.constrain(UEqn());
    solve(UEqn() == -fvc::grad(p));
Continuity Equation :
    p.boundaryField().updateCoeffs();
    #include "TEqn.H"
    volScalarField rAU(1.0/UEqn().A());
    U = rAU*UEqn().H();
    UEqn.clear();
    phi = fvc::interpolate(U, "interpolate(HbyA)") & mesh.Sf();
    adjustPhi(phi, U, p);
    // Non-orthogonal pressure corrector loop
    while (simple.correctNonOrthogonal())
        fvScalarMatrix pEqn
            fvm::laplacian(rAU, p) == fvc::div(phi)
        pEqn.setReference(pRefCell, pRefValue);
        pEqn.solve();
        if (simple.finalNonOrthogonalIter())
            phi -= pEqn.flux();
    #include "continuityErrs.H"
    // Explicitly relax pressure for momentum corrector
    p.relax();
    // Momentum corrector
    U -= rAU*fvc::grad(p);
    U.correctBoundaryConditions();
    sources.correct(U);
T prediction:
solve
        fvm::div(phi, T)
     + fvc::div(J)
The parameters are:
label leftWall = mesh.boundaryMesh().findPatchID("leftWall");
// leftWall
forAll(mesh.boundaryMesh()[leftWall],i)
//std::cout<<i<<"\n";
Q.boundaryField()[leftWall][i].component(tensor::XX) = 1; //or any other values
Q.boundaryField()[leftWall][i].component(tensor::XY) = 0;
Q.boundaryField()[leftWall][i].component(tensor::XZ) = 0;
Q.boundaryField()[leftWall][i].component(tensor::YX) = 0;
Q.boundaryField()[leftWall][i].component(tensor::YY) = 0.8;
Q.boundaryField()[leftWall][i].component(tensor::YZ) = 0;
Q.boundaryField()[leftWall][i].component(tensor::ZX) = 0;
Q.boundaryField()[leftWall][i].component(tensor::ZY) = 0;
Q.boundaryField()[leftWall][i].component(tensor::ZZ) = 0.5;
label fixedWalls = mesh.boundaryMesh().findPatchID("fixedWalls");
// fixedWalls
forAll(mesh.boundaryMesh()[fixedWalls],i)
Q.boundaryField()[fixedWalls][i].component(tensor::XX) = 1; //or any other values
Q.boundaryField()[fixedWalls][i].component(tensor::XY) = 0;
Q.boundaryField()[fixedWalls][i].component(tensor::XZ) = 0;
Q.boundaryField()[fixedWalls][i].component(tensor::YX) = 0;
Q.boundaryField()[fixedWalls][i].component(tensor::YY) = 0.8;
Q.boundaryField()[fixedWalls][i].component(tensor::YZ) = 0;
Q.boundaryField()[fixedWalls][i].component(tensor::ZX) = 0;
Q.boundaryField()[fixedWalls][i].component(tensor::ZY) = 0;
Q.boundaryField()[fixedWalls][i].component(tensor::ZZ) = 0.5;
label rightWall = mesh.boundaryMesh().findPatchID("rightWall");
// rightWallvvv
forAll(mesh.boundaryMesh()[rightWall],i)
Q.boundaryField()[rightWall][i].component(tensor::XX) = 1; //or any other values
Q.boundaryField()[rightWall][i].component(tensor::XY) = 0;
Q.boundaryField()[rightWall][i].component(tensor::XZ) = 0;
Q.boundaryField()[rightWall][i].component(tensor::YX) = 0;
Q.boundaryField()[rightWall][i].component(tensor::YY) = 0.8;
Q.boundaryField()[rightWall][i].component(tensor::YZ) = 0;
Q.boundaryField()[rightWall][i].component(tensor::ZX) = 0;
Q.boundaryField()[rightWall][i].component(tensor::ZY) = 0;
Q.boundaryField()[rightWall][i].component(tensor::ZZ) = 0.5;
// assign Q on internal Field
forAll(mesh.cells(),j)
Q[j].component(tensor::XX) = 1;
Q[j].component(tensor::XY) = 0;
Q[j].component(tensor::XZ) = 0;
Q[j].component(tensor::YX) = 0;
Q[j].component(tensor::YY) = 0.8;
Q[j].component(tensor::YZ) = 0;
Q[j].component(tensor::ZX) = 0;
Q[j].component(tensor::ZY) = 0;
Q[j].component(tensor::ZZ) = 0.5;
//Viscosity of the suspending fluid dimensionlessed by suspending fluid viscosity (nu)
volScalarField ns
        IOobject
            "ns",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        pow( (1.0- (T/Tm)), -1.82)
//Particle shear stress np=ns-1;
volScalarField np
        IOobject
            "np",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        ns-1
//calculating normal stress viscosity nN=(Kn*pow(T/Tm,2)*pow(1-T/Tm,-2));
volScalarField nN
        IOobject
            "nN",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
//calculating hindrance mobility function f(T)=(1-T/Tm)*pow(1-T, c-1), where c=[2,4]
volScalarField f
        IOobject
            "f",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
//calculating local shear rate g(gamma dot) given by sqrt(2E:E)
//volScalarField g(1.41421*sqrt(magSqr(symm(fvc::grad(U))))+nl);
// where nl is the non local shear rate
volScalarField g
        IOobject
            "g",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
//calculating particle normal stress diagonal tensor Epnn1=nu*nN*g*Q;
volTensorField Epnn1
        IOobject
            "Epnn1",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        nu*nN*g*Q
//volVectorField J(2*a*a/(9*nu)*pow(1-T,c)*(fvc::div(Ep)));
volVectorField J
        IOobject
            "J",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        -2*a*a/(9*nu)*f*fvc::div(Epnn1)+fvc::laplacian(2*a*a/(9*nu)*f*2*nu*np, U)
I prepared my solver by modifying simpleFoam solver. Thanks again.
Regards
M Reddy
Thread Tools
Trackbacks are On
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
