property values in each cells
Old   February 25, 2013, 23:56
Default property values in each cells
Thomas
Thomas Jacob is an unknown quantity at this point
how can i get the values of pressure in each cell
Thomas Jacob is offline   Reply With Quote
Old   February 26, 2013, 06:15
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Hi Thomas,
You can access the cell center value of pressure field p by p[cell_label].
If you want to access every cell, you can use
forAll(p, cellI)
    //You can use p[cellI]
Using the "findCell" function, you can find the cell label that contains
the position you specify:
vector pos(0,0,0); //Change the position as you like
label cellI = mesh.findCell(pos);
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 19:18
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 11:57
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
