February 25, 2013, 23:56 |
property values in each cells
Thomas
Rep Power: 12 |
how can i get the values of pressure in each cell
February 26, 2013, 06:15 |
Fumiya Nozaki
Rep Power: 18 |
Hi Thomas,
You can access the cell center value of pressure field p by p[cell_label]. If you want to access every cell, you can use Code:
forAll(p, cellI) { //You can use p[cellI] } the position you specify: Code:
vector pos(0,0,0); //Change the position as you like label cellI = mesh.findCell(pos); Fumiya |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 19:18 |
[ICEM] error analysis | despaired student | ANSYS Meshing & Geometry | 7 | June 27, 2012 11:57 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
