June 20, 2011, 08:26 |
InterFoam vs InterDyMFoam
Rose Lambert
Rep Power: 14 |
Hi Everyone,
I am a new user of OpenFOAM and am aiming to use it as part of my Master thesis. I am modelling a floating object under the influence of waves (I will use the groovyBC boundary condition). However I am a little confused as to the difference between the interFoam solver and the interDyMFoam solver. Could someone please explain the difference between these solvers and for what scenarios they are best used? Is interDyMFoam specifically for use with a dynamic mesh? Thanks in advance, Rose |
June 21, 2011, 03:21 |
Arne Stahlmann
Rep Power: 17 |
Generally, interDymFoam is interFoam plus mesh modification. This mesh modification can either consist of mesh refinement in local areas (e.g. to sharpen the fluid interface, as already said) or of a mesh motion part due to calculated quantities (e.g forces).
If you have to decide which one you need, ask yourself the question if your floating object is moving in the water due to wave forces, or if it is fixed. In case of mesh refinement at the interface: Do you really need it (as it can take quite much computational time), or is a generally (statically) refined mesh in the wave area enough for you... Arne Last edited by Arnoldinho; June 21, 2011 at 04:02. |
June 21, 2011, 05:21 |
Rose Lambert
Rep Power: 14 |
Thank you for your replies. My floating object is not fixed and I am particularly interested in what happens at the interface, so I guess that leads to using interDyMFoam. Maybe I will try both interFoam and interDyMFoam to compare results.
Thanks again, Rose |
March 6, 2013, 10:56 |
InterDyMFoam
Rep Power: 13 |
Does anybody knows what method is used in InterDyMFoam to refine boundary surface meshes?
interdymfoam, interfoam |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 06:36 |
Slow interFoam compared with other CFD tools? | Ralph M | OpenFOAM Programming & Development | 1 | November 17, 2010 06:46 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
alpha or alpha1 in interFoam & interDyMFoam | wavytracy | OpenFOAM Bugs | 3 | September 10, 2009 02:51 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
