y+ values calculation in OpenFoam
Like Tree1Likes
  • 1 Post By colinB
Old   March 7, 2013, 11:34
Exclamation y+ values calculation in OpenFoam
AndreiCFD
andrei.cimpoeru is on a distinguished road
Is it anyone familiar with the calculation of the y+ value as well as the turbulent KE and turbulent omega?
I am have an airfoil and I am using Komega SST with simpleFoam with wall functions and when I look at my residuals my pressure doesn't drop and I am ending up with high residuals.
I am interested to drop my residuals below 10^(-4).......
Any ideas
Many thanks
Andrei
andrei.cimpoeru is offline   Reply With Quote
Old   March 8, 2013, 03:13
Sasan Ghomi
sasanghomi is on a distinguished road
If your problem is caculation of y+ , So you can use :
yPlusRAS -----> incompressible flow
yPlusRAS -compressible ---------> compressible flow
Sasan.
sasanghomi is offline   Reply With Quote
Old   March 8, 2013, 03:23
AndreiCFD
Ok then.
I run yPlusRans but i get a min value a max value and an average value... what does mean?
Old   March 8, 2013, 05:27
colinB is on a distinguished road
Hey there,
i guess you are referring to yPlusRAS when you wrote yPlusRans?
However to answer your question:
y+ value is a dimensionless height of the first cell on a surface.
But when this cell hight is varying over the surface you get different values.
Since providing the cell heights of all cells is quite a lot information
as a rough indication only the smallest the highest and the average of
all cell heights are given.
Usually the max value is the most crucial one since you can see with this
one whether the values exceed the maximum allowable for using
wall functions.
I hope this helps
regards
Colin
Alhasan likes this.
colinB is offline   Reply With Quote
Old   March 8, 2013, 05:39
AndreiCFD
so for a High Re I should have a yplus around 30 when using wall functions
therefore I should keep an eye just on the max value of the yplus when running yPlusRas....
Collin correct me plz if I am wrong.
Thanks
Incoherent values of Cl in 2D calculation Santos-Dumont FLUENT 1 May 1, 2011 21:15
The calculation efficiency of OpenFOAM chiven OpenFOAM Running, Solving & CFD 4 September 14, 2009 04:44
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Warning 097- AB Siemens 6 November 15, 2004 04:41
