-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   compressibleInterFoam : biphasic, compressible, equation of state (http://www.cfd-online.com/Forums/openfoam/114426-compressibleinterfoam-biphasic-compressible-equation-state.html)
clementolivier March 11, 2013 05:04
Hi everyone,
I am a new user on OpenFoam. I would like to run a compressible and biphasic case. It seems that, it is possible using compressibleInterFoam. However, I also want to change the two fluids' equation of state. Do I have to modify the C code of the solver, or there is a simpler way ?
Thanks ;)
Best regards
Clément
nimasam March 11, 2013 12:41
you should change source code, there is no easier task
clementolivier March 12, 2013 04:33
Thank you for your answer, I will get back to work !
olivierG March 12, 2013 05:36
hello,
This is already possible to change the fluid equation of state.
Take a look in the depthCharge tutorial, in TransportProperties : would can choose constant, linear, perfectFluid, ...
Regards,
olivier
clementolivier March 12, 2013 06:04
Thank you for your answer olivierG.
I can see how to change the constants of the model (nu,rho,rho0,psi), but I do not quite see how to change the formula of the equation of state.
Do you mean that the argument of transportModel specifies it ? If it is the case, is there any exhaustive list of all allowed arguments ?
olivierG March 12, 2013 06:18
hello,
First what the state equation you would use ?
And which version of openfoam do you use ?
To get the list of state equation, put "dummy" instead of perfectFluid : you will get a list.
To find more info, you should take a look at the source code. this part was in the solver for the 2.1.x version, but has moved with the 2.2.x
regards,
olivier
clementolivier March 12, 2013 06:39
Thank you again for your help
I want to use the equation of state called the Stifeffened Gas Equation of State for the liquid, and the Perfect Gas Equation of State for the gas.
I am currently usig OpenFoam v2.1.1.
I am sorry but I have done a grep -rin "perfectFluid" * in the directory tutorials/multiphase/compressibleInterFoam, and it is nowhere written. Can you explain more precisely where whould I type "dummy".
I am right now reading the C++ code in order to fix my problem.
olivierG March 12, 2013 06:46
hello,
1) in your tuto case, set "dummy" (or anythink), then launch the solver: you will get an error message, which will say dummy is not a equation of state, and will list the possible one.
2) For the 2.1.1, the definition is in the solver source, never in the tutorial. take a look at applications/solvers/multiphase/compressibleInterFoam/phaseEquationsOfState/ in your installation directories.
regards,
olivier
clementolivier March 12, 2013 07:10
Thanks,
I still do not see where should I set "dummy" (or anything).
Moreover the directory applications/solvers/multiphase/compressibleInterFoam/phaseEquationsOfState/ does not exist in my version. I will get I last version and it will be easier for me to communicate.
regards,
Clément
olivierG March 12, 2013 07:22
hello,
Sorry, i wasn't clear.
copy the tuto (depthCharge3D).
Open depthCharge3D/constant/transportProperties
You have 2 phase, air and water.
In the definition of water, you should have:
equationOfState
type perfectFluid;
rho0 1000;
R 3000;
Just change "perfectFluid" by "dummy", and run the solver.
regards,
olivier
clementolivier March 12, 2013 07:36
Thank you very much,
Indeed in the last version, I can see everything you are talking about.
I think,this will fix my problem.
Thank you again
Regards,
Clément
aylalisa August 13, 2013 13:10
equationOfState - R
Hallo Olivier,
I am not clear about equationOfState models.
What meanding has R?
Originally Posted by olivierG (Post 413377)
hello,
equationOfState
type perfectFluid;
rho0 1000;
R 3000;
regards,
olivier
Aylalisa
olivierG August 22, 2013 04:15
hello,
R is the specific gaz constant = R/M (M=molar mass).
R is used to calculate the compressibility psi = 1/RT.
For liquid, you still need to set compressibility and use the same law (you can guess this from the name "perfectLiquid"). But R is really bigger, to act as a very low compressible media.
regards,
olivier
sh.d August 25, 2013 11:30
help
hi
In compressible liquid/gas flows, the pEqn reads :
fvm::ddt(psi,p)+fvc::div(phi)+fvm::div(phid,p,".." )-fvm::laplacian(..,p)
Can someone tell me what is the form of the differential equation?
Tobi September 24, 2013 06:17
Hello sh.d,
the equation for that formula should be something like that:
\psi \frac{\partial p}{\partial t} + \nabla\phi + \nabla (\phi_d p ...) + \nabla \phi \nabla (p)
I think its not correct but gives you a hint to read the lines.
