Home > Forums > OpenFOAM
interpolated field at iso-surface 0.5
Old   March 11, 2013, 12:03
Default interpolated field at iso-surface 0.5
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
I would like to interpolate a specified field on the iso-surface 0.5 of the color function alpha1 (interFoam) and then sum up all the contribution to get a kind of average value of that field at the interface. Is there a simple way to do that? I tried with sampling and function object but i didn't manage to get what i want.
any help is appreciated!
best
andrea
Andrea_85 is offline   Reply With Quote
Old   March 12, 2013, 05:26
Yogesh Bapat
ybapat is on a distinguished road
You can take a look at isoSurface class in sampledSurface. I have not tried it, but I think it will help you.
Regards,
-Yogesh
ybapat is offline   Reply With Quote
Old   March 12, 2013, 06:50
Andrea Ferrari
thanks i solved it adding these lines in my sampleDict
constantIso
// Iso surface for constant values.
// Triangles guaranteed not to cross cells.
type isoSurfaceCell; // always triangulated
isoField alpha1;
isoValue 0.5;
interpolate false;
regularise false; // do not simplify
// mergeTol 1e-10; // Optional: fraction of mesh bounding box
// to merge points (default=1e-6)
best
andrea
Old   March 13, 2013, 19:58
Assistant Moderator
Bernhard Gschaider
Originally Posted by Andrea_85 View Post
Hi all,
best
andrea
Depends on your definition of "simple". I lifted this from one of the examples in swak4Foam:
    createInterface
        type createSampledSurface;
        outputControl timeStep;
        outputInterval 1;
        surfaceName interface;
        surface {
            type isoSurface;
            isoField alpha1;
            isoValue 0.5;
            interpolate true;
    height
        type swakExpression;
        valueType surface;
        verbose true;
        expression "pos().y";
        accumulations (
            min
            max
This gives you the minimum and maximum height of the surface, but other expressions (for instance "otherField*area()/sum(area())") and accumulations (sum) are possible (this should give you the area weighted average of otherField on that surface)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
grading in the BlockMesh Astarta OpenFOAM Native Meshers: blockMesh 1 May 23, 2011 15:39
Failed 5 mesh checks Astarta OpenFOAM Native Meshers: blockMesh 3 May 10, 2011 14:42
Iso Surface for a region FabioT FLUENT 0 December 9, 2010 07:05
Vorticity iso surface around propeller in CCM+ Dan CD-adapco 2 January 23, 2007 15:17
