March 17, 2013, 21:22 |
Is OpenFoam Slower Than Starccm?
Md. Naimul Haque
Dear All,
Greetings! I am running, 2D simulation with standard kepsilon model, I have around 100k grid cells. I run the 10 sec, simulation in Starccm V6. it takes around 4 days in single processor with all second order dicretization. but the same simulation if I run in OpenFOAM by parallel computing (2 processors) to complete 10 sec simulation is takes 6.5 days. Single processor takes more. My fvSchemes and fvSolution file are attached here. How can I speed up my case? Please, help. I will be ever grateful. fvSchemes.docx fvSolution.docx |
March 18, 2013, 11:58 |
Rep Power: 18 |
In the fvSolution file, Try GAMG (multigrid method) to solve p and pFinal.
And I think that you should avoid under relaxation when using the PISO method. Under relaxation should be used when using the PIMPLE method and employing more than one outer corrector. |
March 18, 2013, 17:39 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Another possibility is the Operating System used. Since the initial attachments are of type "docx", that leads me to suspect that both Star-CCM+ and OpenFOAM were executed on Windows. It's best that you use both on Linux, for the best performance! Yet another note: 2D in Star-CCM+ is probably optimized; while OpenFOAM always does things in 3D, although it can disable the 3rd dimension and run things as if it were 2D. Best regards, Bruno
March 19, 2013, 03:40 |
Md. Naimul Haque
Dear fsaltara and Bruno,
Greetings! Thank you very much for your valuable suggestions. I run Starccm in windows and OpenFOAM in Ubuntu. First, I run Kepsilon model without under relaxation than I found the simulation was used to explode after 10 to 15 iterations. Then I used UR to make the simulation stable. I will remove and try again as u guys have suggested. Whatever, Thank you very much for our kind advice. |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
2009 OpenFOAM Summer School in Zagreb, Croatia | hjasak | OpenFOAM Announcements from Other Sources | 0 | March 27, 2009 12:08 |
Summer School on Numerical Modelling and OpenFOAM | hjasak | OpenFOAM | 5 | October 12, 2008 13:14 |
Getting OpenFOAM to coexist with an existing JAVA VM | nik777 | OpenFOAM Installation | 5 | February 22, 2007 07:21 |
