Home > Forums > OpenFOAM
Zero iteration step, why??
Old   March 18, 2013, 18:32
Question Zero iteration step, why??
hz283 is on a distinguished road
Hi All,
In one of my simulations, I used k-epsilon model, and got the following output:
pEqn.H_1: rho max/min : 1.1966 1.19659
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors (Low Ma): sum local = 8.61908e-16, global = -2.16302e-17, cumulative = -2.87666e-15
pEqn.H_2: rho max/min : 1.19661 1.1966
GAMG: Solving for phd, Initial residual = 0.00121095, Final residual = 8.07744e-06, No Iterations 8
GAMG: Solving for phd, Initial residual = 0.00275727, Final residual = 2.14566e-05, No Iterations 5
GAMG: Solving for phd, Initial residual = 0.00166235, Final residual = 9.90116e-06, No Iterations 4
pEqn.H_1: rho max/min : 1.19661 1.1966
time step continuity errors (Low Ma): sum local = 7.21639e-16, global = -2.3332e-17, cumulative = -2.89999e-15
pEqn.H_2: rho max/min : 1.1966 1.19659
DILUPBiCG: Solving for epsilon, Initial residual = 5.56717e-07, Final residual = 5.56717e-07, No Iterations 0
DILUPBiCG: Solving for k, Initial residual = 4.73169e-07, Final residual = 4.73169e-07, No Iterations 0
Pimple Loop End: rho max/min : 1.1966 1.1966
Pimple Loop End: nu max/min : 1.528e-05 1.528e-05
ExecutionTime = 1907.55 s ClockTime = 1915 s
From above, we can see the number of the iterations is zero. What does it mean? Does it mean k and epsilon are solved using explicit method? (I have this think because in the compressible solvers, the density is solved using explicit method with zero iteration step). Why are they (k and epsilon) are solved with zero iteration steps?
In the beginning of the simulations, they are not zero, but 3-5 steps.
Does anybody give me some hints about this?
best
H
hz283 is offline   Reply With Quote
Old   March 18, 2013, 19:05
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Hi H,
The number of iteration is 0 since the initial residual is less than the convergence criteria you set. So for all intent and purpose, the solver is assuming that the epsilon and k fields are "converged" and do not need iterations.
If you do want to have more iteration, decrease the convergence criteria for k and epsilon.
Julien
julien.decharentenay is offline   Reply With Quote
Old   March 18, 2013, 19:57
Hi Julien,
When I change the tolerance in system/fvSolution as follows:
k
solver smoothSolver;
smoother GaussSeidel;
tolerance 1e-9;
relTol 0;
nSweeps 1;
/* solver PBiCG;
preconditioner DILU;
tolerance 1e-010;
relTol 0.1;
epsilon
tolerance 1e-9;
relTol 0;
nSweeps 1;
/* solver PBiCG;
tolerance 1e-010;
relTol 0.1;
The output from the solver is like the followings:
time step continuity errors (Low Ma): sum local = 7.207e-16, global = -8.28698e-18, cumulative = -7.88457e-15
DILUPBiCG: Solving for epsilon, Initial residual = 4.13716e-07, Final residual = 4.13716e-07, No Iterations 0
DILUPBiCG: Solving for k, Initial residual = 5.42019e-07, Final residual = 5.42019e-07, No Iterations 0
It is a little strang that changing the tolerance does not change the iteration number. Besides, I found that linear algebraic solver DILUPBiCG is not the one I specified in the fvSolution file (smoothSolver). When I change the linear algebraic solver for the velocity U, it indeed changes. So I am a little confused about the controling parameter for k and epsilon. Why can they not be changed in system/fvSolution although they should be?
Thank you so much!
hz283
Originally Posted by julien.decharentenay View Post
Hi H,
Julien
Old   March 18, 2013, 20:08
Hi Julien,
If during the simulation the iteration number of k and epsilon is always zero, does it mean that actually the values of k and epsilon are not updated by the solver? Thanks.
Hi H,
Julien
Thread Tools
Trackbacks are On
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 62 June 16, 2016 03:01
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 04:41
why PIMPLE doesn't converge at each time step but no diverging? immortality OpenFOAM Running, Solving & CFD 7 May 19, 2013 14:16
time step and iteration tony25800 FLUENT 2 February 3, 2012 05:33
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
