March 24, 2013, 22:08 |
alpha1 grows unbounded in interDyMFoam
Tayo
Hello all,
I'm running rising bubble case using interDyMFoam. The issue is that alpha1 blows up whenever I run with flow velocity i.e. maximum alpha1 grows unbounded beyond 1 and minimum alpha1 also grows beyond zero even after the first time step. However, it behaves fine when I run without flow velocity. I've tried running implicitly and then played around with the div(phi,alpha) & div(phirb,alpha) in fvSchemes, and then with calpha and nAlphaSubCycles in fvSolution. I've even set maxCo & maxAlphaCo to 0.01 yet it still grows. Please I need ideas on how to make alpha1 stay bounded between 0 and 1 irrespective of flow velocity. I would really appreciate any help. Thank you. |
March 27, 2013, 16:10 |
Tayo
Please I'm still waiting for response/ideas on how to keep alpha1 bounded using interDyMFoam. Thank you.
March 27, 2013, 16:47 |
Lieven
Rep Power: 22 |
Hi Tayo,
A thing you can try (at least this is what I would do) is to select the 'upwind' interpolation for all operators in the fvSchemes. It is first order, so you don't want to keep it, but it is bounded. So you should not get the under/overshoots. Next, replace each upwind by a second order scheme until you see the problem arising. For that operation you need to pick a more advanced scheme (TVD, explicitly bounded scheme, filtered, ...). Cheers, Lieven |
March 27, 2013, 17:44 |
Tayo
Thanks Lieven,
I've just tried upward scheme on div(phi,alpha) but it still grows unbounded, then, I tried vanLeer01 but same result. I'm currently using limitedVanLeer 0 1 but it's not looking any different. I'm currently running at time step of 1e-6sec. The wield thing is that when I ran the case without adaptive meshing (interFoam), alpha1 didn't blow up although I had to use maxCo and maxAlphaCo of 0.1. So I strongly think it has to do with interDyMFoam but I don't know how to correct the solver. I really need adaptive meshing for my case. |
March 28, 2013, 08:16 |
Lieven
Rep Power: 22 |
hi Tayo,
I really meant to use the upward scheme for all operators as starting point. At this point, there is really no reason yet to think it is a problem of the solver. Low mesh quality or poor initial conditions e.g. are more likely. Cheers, L |
April 1, 2013, 15:18 |
Tayo
Update!
I noticed that I got worst void fraction results as I increased calpha and calpha = 0 had "best result" (instead of the reverse occuring). Upward schemes also made it worst as expected too. Could this "unboundedness" be as a result of the interfaceCompression scheme? Any other recommendable schemes for the div(phi, alpha) and div(phirb, alpha)? Last edited by tayo; April 1, 2013 at 16:28. |
April 4, 2013, 03:42 |
Tayo
Hello all,
I've been able to fix the issue. First of all, I discovered that the problem of unbounded alpha1 was not unique to interDyMFoam alone, it also blew up in interFoam. By the way, my flow velocity was quite high (~1m/s) but alpha1 still blew up even with low vel (~0.01m/s). The div schemes did not help much, neither did a very very low maxAlphaCo (0.01). To solve it, I solved the solution implicitly setting Sp as zero. But for Su term, I defined as divU*alpha1. This extra divergence term helped keep the alpha1 equation stable along with the right combination of maxAlphaCo. This has kept my max alpha1 bounded to 1 while you won't lose computation time since maxAlphaCo of 0.4 has worked fine. Hope this helps anyone else with unbounded alpha1 issue. Thanks |
July 14, 2013, 10:36 |
Kshitij kunte
I simulating a nozzle flow using k-e turbulence model in interFoam, and getting a negative phase fraction. I'm a newbie to C programming, can you tell where to add the corrections you have given. I ran a grep command to find out where the SpType is used and found these locations applications/solvers/multiphase/interFoam/LTSInterFoam/MULESTemplates.C src/finiteVolume/fvMatrices/solvers/MULES/MULESTemplates.C But didnt find where Sp is defined in them, can you please guide me through this. |
July 17, 2013, 17:38 |
#9 | |
Tayo
September 5, 2013, 03:09 |
#10 | |
Hale
Rep Power: 12 |
I am very new to OpenFoam and C++ coding and I'm facing the same problem as yours where alpha1 becomes negative. Would you please post the files with required changes in order to avoid this problem? I really appreciate your help. Hale |
September 10, 2013, 03:13 |
#11 |
Have you double checked your boundary conditions?
September 13, 2013, 08:14 |
#12 |
Hale
Rep Power: 12 |
September 17, 2013, 04:42 |
#13 |
Galchenko Olga
Hi Hale!
I'm having the same problem as discussed before, though adding Su term as tayo adviced didn't help. What boundary conditions caused you problem? May be I have some similliar mistake.. Regards, Olga |
September 17, 2013, 05:00 |
#14 |
Hale
Rep Power: 12 |
Hi Galchenko,
I had zeroGradient on the both pressure and velocity for the inlet and zeroGradient for the velocity and a negative pressure for the outlet, which was equal to the pressure difference between inlet and outlet. This was apparently a very poorly defined boundary condition for my system which made it very unstable and therefore alpha1 became negative. My intention by setting those boundary conditions was to let the model determine the velocity at the inlet but the system was apparently an overdetermined system which could not be solved in OF. I changed the BC to the following and it worked fine: Inlet: U: fixedValue uniform (x 0 0); p_rgh: buoyantPressure; Outlet U: zeroGradient p_rgh: fixedValue uniform 0; |
April 1, 2015, 12:27 |
#15 |
zhouhoucun
Rep Power: 11 |
Hello,tayo, I meet the same problem as you with interPhaseChangeFoam, could you send me you case files for me?Thank you in advance
May 8, 2015, 03:35 |
#16 |
Samantha Chong
Negative alpha1 using interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 14 | March 2, 2013 10:26 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
alpha1 is unbounded | GerhardHolzinger | OpenFOAM Running, Solving & CFD | 1 | October 17, 2012 05:25 |
What is alpha1 in interDyMFoam | physics1 | OpenFOAM Running, Solving & CFD | 2 | July 4, 2012 07:20 |
alpha or alpha1 in interFoam & interDyMFoam | wavytracy | OpenFOAM Bugs | 3 | September 10, 2009 02:51 |
