[swak4Foam] how to use funkySetFields function in muliregion case
Like Tree1Likes
  • 1 Post By Mohammad Jam
Old   April 26, 2013, 05:12
Default how to use funkySetFields function in muliregion case
kob
bryant_k is on a distinguished road
Hello everyone
I want to use funkySetFields function to set the initial nonuniform field in multiregion case.The solver that I am useing is chtMultiregionFoam and the case is modified according to the tutorials name multiRegionHeater.I know how to use funkySetFields in a case which have a singal region.
With the command:
 funkySetFields -time 0
I can have a initial fields I need successfully.
But in a multiregion case I can not make it work.I know that the foamToTecplot have the function for multiregion.So I try the command according to that:
funkySetFields -region heater -time 0
or
funkySetFields  -time 0 -region heater
but it is wrong.
Can you tell me how can I use this funciton in multiregion case?
Thank you very much!
regards!
bryant_K
bryant_k is offline   Reply With Quote
Old   April 26, 2013, 05:28
Assistant Moderator
Bernhard Gschaider
Originally Posted by bryant_k View Post
Hello everyone
With the command:
or
but it is wrong.
regards!
bryant_K
Define "wrong".
I've used it in the past with -region and it worked. But I think that was in "command line"-mode. You're using a dictionary, right? Try specifying an entry "region heater;" there. I must check the source but it is possible that in dictionary mode the -region-option is ignored
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 27, 2013, 05:41
kob
Thank you for your reply.
I have put the file name funkySetFieldsDict into folder both "system" and "system/heater". Then I run the command
it occured error:
can not open
file:../../multiRegionHeater/system/heater/funkySetFieldsDict.heater at line 0.....
But when I run the command
,it can run fluently without error.
But it just changed the file in folder "0" rather "0/heater".
Then I add entry in the file funkySetFieldsDict:
expressions
    Q1
        field Q;
        expression "...";
        condition "..."
        region heater'
It can run without any error,but it also changed the field in folder "0" only.
Can you tell how to add the entry and how can I get fields I want?
bryant_k
Old   April 28, 2013, 16:54
Assistant Moderator
Bernhard Gschaider
it occured error:
can not open
I checked. It works like this. Look at the error message: the location of the dictionary is in a subdirectory of system, not system itself
expressions
    Q1
        field Q;
        expression "...";
        condition "..."
        region heater'
Old   April 10, 2016, 23:01
Saurabh Tandon
STutexas is on a distinguished road
Hi
Thank you for your post and your documentation. I am trying to use funkySetFields for setting heterogeneous values of fields in different cell zones. I have already created 2 separate cell zones and I use the following commands in my funkySetFieldsDict file:
setDT
field DT;
keepPatches true;
expression "2e-09";
zone PoreWater;
setTb
field Tb;
keepPatches true;
expression "2";
zone PoreWater;
My problem is that funkeSetFields changes the values of DT, Tb fields in the whole domain and not just in the zone PoreWater. Please let me know what am I doing wrongly.
Thank you.
Saurabh
STutexas is offline   Reply With Quote
Old   April 16, 2016, 12:05
Retired Super Moderator
Bruno Santos
Quick answer: Insufficient details. Please provide more details, namely:
  1. What's the exact command you are using?
  2. Where are the "funkySetFieldsDict" files placed in your case? Namely inside which folder (directory)?
Old   April 16, 2016, 20:46
Saurabh Tandon
Hi
Thank you for your reply. I am using the command funkySetFields -time 0. My funkySetFields file is in system directory. I believe that I am using the command right but the value in the entire domain is changed not just in the defined cell.
Thank you.
Saurabh
Old   April 17, 2016, 14:22
Bruno Santos
Quick answer: Then if you want the correct region to be affected, then you need to:
  1. Place a "funkySetFieldsDict" inside the folder "system/PoreWater".
  2. Run like this:
    funkySetFields -time 0 -region PoreWater
This was explained in the posts above
Old   April 17, 2016, 14:47
Saurabh Tandon
Hi Bruno
Thank you for your suggestion . But I am not running split mesh during preprocessing. I have regions divided (using toposet) into separate cells with names like pore water, bound water, hydrocarbon etc. I use createBaffles to divide the mesh into separate regions. I set Boundary conditions on the 2 generated boundaries. Now I want to set different (hetrogeneous) properties in these different cells. There is only one system folder .
Please let me know if running splitmesh is necessary for me to properly define these different phases. I am not doing that for now .
Thanks again for your feedback. It has been very helpful.
P.S. I have attached is a simplified .msh that I use. Please unzip and open it with gmsh if you would like a better visualization of my problem. Thanks again.
Saurabh
Old   April 17, 2016, 15:04
Bruno Santos
Quick answer: Sorry, I read the other post too fast
You should use something like this:
  setTb
    field p_rgh;
    keepPatches true;
    expression "3";
    condition  "zone(porosity)";
Source: http://openfoamwiki.net/index.php/Co...funkySetFields - chapter "Expression syntax" and section "Initialise a pressure field gradient due to gravity".
edit: And you forgot to attach. Either way, I tested with the tutorial case "multiphase/interFoam/ras/angledDuct"
Old   May 1, 2016, 21:38
Saurabh Tandon
Hi Bruno
Thank you for all the help and your advice. I have used set fields for simulation of my case. Thanks again for the help.
I have another question pertaining to the same problem. I am using groovyBC in my simulations. This is what my code looks like.
boundaryField
PoreWall
type groovyBCDirection;
value uniform (0 0 0);
valueExpression "vector (0, 0, Minf)";
gradientExpression "vector(0,0,0)";
fractionExpression "symmTensor(1/(1+D/(rho2*mag(delta()))),0,0,1/(1+D/(rho2*mag(delta()))),0,1/(1+D/(rho1*mag(delta()))))";
evaluateDuringConstruction 0;
variables
4
"D=3e-09;"
"rho2=10e-06;"
"rho1=10e-06;"
"Minf=4.2e-07;"
but I would like to change the values of rho2, rho1 and Minf based on the set type in the mesh. For example:
if (set_of_face) == set1
Minf = 4.2;
else
Minf = 2.2;
Is it possible to set type non uniform values in the groovyBCset. I really appreciate all the help that you have given and all the help.
Saurabh
Old   May 2, 2016, 14:42
Assistant Moderator
Bernhard Gschaider
Hi Bruno
boundaryField
PoreWall
variables
4
"D=3e-09;"
"rho2=10e-06;"
"rho1=10e-06;"
"Minf=4.2e-07;"
Minf = 4.2;
else
Minf = 2.2;
Saurabh
You can always use the condition-operator in expressions "cond ? 4.2 : 2.2" for such a thing with cond being your conditon. I just don't understand what you mean with "set type in the mesh"
Old   August 1, 2016, 04:40
Mohammad Jam is on a distinguished road
it occured error:
can not open
expressions
    Q1
        field Q;
        expression "...";
        condition "..."
        region heater'
bryant_k
Hi Dears
u should probably change funkySetFieldsDict name with funkySetFieldsDict.heater after u put funkySetFieldsDict in heater folder in system folder
(ADD dot heater)= .heater
then run funkySetFields -time 0 -region heater
thiagopl likes this.
Mohammad Jam is offline   Reply With Quote
Old   April 21, 2020, 05:47
Default funkySetFields
  #14
Muyiwa
Muyiwa is on a distinguished road
Hello Foamers
Please show me how to use funkySetFields to create an undulating initial field for alpha.water in the damBreak tutorial. I want to use undulating surface instead of the boxToCell used in the setFields of the tutorial.
Muyiwa is offline   Reply With Quote
Old   January 27, 2021, 04:10
ESI
ht2017 is on a distinguished road
Originally Posted by Muyiwa View Post
Hello Foamers
do you have success with funkySetFields? If you did it. could you share with me how to do it?
ht2017 is offline   Reply With Quote
Old   October 15, 2021, 02:50
harshawardhank
harsha_kulkarni is on a distinguished road
Hello Foamers
Have you succeed in your work..
I want to set dam tilted at an angle of 50 degree
harsha_kulkarni is offline   Reply With Quote
funkysetfields
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
