Turbulent Heat Flux Question
1 Attachment(s)
Hello Foamers!!! I am somewhat baffled by some of the results I've acquired in my LES simulation. It is a natural convection turbulent boundary layer flow over a heated vertical plate. Herein lies my question, is it possible to accurately capture <u'u'> and <T'T'>, but overpredict the turbulent heat flux, <u'T'>? That is essentially what my results show; thus, I am assuming mesh resolution may be the issue.These are the results.
Any feedback will be immensely appreciated? |
Hi deji,
discrepancy for <u'T'> is too big so that it seems to me that the problem might be just in the plotting (normalization of data or something like that), check it carefully. Regards |
Thanks much for the feedback Dejan. I will definitely look into that.
Problem solved!! It was a normalization problem...Thanks much for the feedback Dejan!:D
You're welcome! :)
turbulent heat flux
Dear deji,
How you have calculated the turbulent heat flux. I am simulating the natural convection case in vertical channel. Please tell me how you have calculated turbulent heat flux in FLUENT. regards saad |
