something wrong when I compile swak4Foam
Recently I try to compile swak4Foam.But I failed.
I use OpenFOAM-2.1.1 and bison:2.4.1,flex 2.5.35. It tells me something wrong with the function,as show below: PatchValueExpressionParser.yy:476: error: no matching function for call to ‘Foam::Field<Foam::SymmTensor<double> >::Field(Foam::tmp<Foam::Field<Foam::Tensor<double > > >)’ ............ PatchValueExpressionParser.yy:666: error: no matching function for call to ‘Foam::Field<Foam::SymmTensor<double> >::Field(Foam::tmp<Foam::Field<Foam::Tensor<double > > >)’ ............ swakCodedFunctionObject.C:292: error: no matching function for call to ‘Foam::swakCodedFunctionObject::updateLibrary()’ ........... groovyFlowRateInletVelocityFvPatchVectorField.C:12 4: error: ‘flowRate’ was not declared in this scope Who can tell me why?I compiled successfully on OpenFOAM-2.1.0 but fail on OpenFOAM-2.2.0 |
Anyway: which version of swak do you have? Older versions than 0.2.3 will not compile on OF 2.2 (and for 2.2.0 you need a manual fix ... see the page on the Wiki). Ah. And which variant of the sources do you have? The 1.x or the 2.x-version? |
