June 4, 2013, 05:45 |
buoyantSimpleFoam
Samuele Z
Rep Power: 18 |
Dear All,
I am trying a 2D simulation, using the buoyantSimpleFoam solver. I have a problem with the very first iteration, since I get this error: Code:
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/steady$ buoyantSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : buoyantSimpleFoam Date : Jun 04 2013 Time : 11:34:52 Host : "lab-laptop" PID : 4155 Case : /home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/steady nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model laminar Calculating field g.h Reading field p_rgh SIMPLE: convergence criteria field p_rgh tolerance 0.001 field U tolerance 0.0001 field T tolerance 0.001 Starting time loop Time = 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.00427575, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0103943, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0995407, No Iterations 7 DICPCG: Solving for p_rgh, Initial residual = 0, Final residual = 0, No Iterations 0 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" #6 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" #7 __libc_start_main in "/lib/libc.so.6" #8 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" Floating point exception lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/steady$ Thanks a lot, Samuele |
buoyantSimpleFoam | rajeshkunwar | OpenFOAM | 0 | September 24, 2012 02:52 |
buoyantSimpleFoam | samiam1000 | OpenFOAM Running, Solving & CFD | 0 | February 22, 2012 08:20 |
Error message when using buoyantSimpleFoam | almir | OpenFOAM | 3 | June 8, 2011 07:02 |
buoyantSimpleFoam velocity oszillation 1.6-ext | preibie | OpenFOAM Running, Solving & CFD | 4 | May 13, 2011 04:09 |
Running buoyantSimpleFoam with oodles data as initialisation | samulu | OpenFOAM | 5 | November 19, 2009 11:49 |
