Error when I try a case with pimple instead of simple solver
Dear All,
I have a problem with a transient simulation. Actually, I do have a case with a steady solution and I have calculated it. I am now trying to calculate the same solution as the limit of the unsteady counterpart. But as soos as I run Code:
buoyanPimpleFoam Code:
buoyanSimpleFoam Code:
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/pseudoTransient$ buoyantPimpleFoam Thanks a lot, Samuele |
I forgot my fvSolution file. Here it is:
/*--------------------------------*- C++ -*----------------------------------*\ |
Hey
I did not understand the problem completely but you can make a small change in your fvSolution by this PIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p_rgh 1e-2; U 1e-3; h 1e-3; G 1e-3; } } replace it by this PIMPLE { momentumPredictor no; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } relaxationFactors { p 0.7; U 0.3; T 0.5; k 0.5; omega 0.5; nut 0.5; R 0.5; nuTilda 0.5; } see if it works. |
I get this error
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/pseudoTransient$ buoyantPimpleFoam |
Can you describe your case a little bit? and the boundary conditions as welll
Sure. I can share it, if you agree. Please, send an email to samuele.zampini@gmail.com and I'll send the case back to you.
residualControl
I got the same error message as you and was able to fix it by adding this to my fvSolution file: Code:
residualControl Joachim Quote:
