Home > Forums > OpenFOAM
buoyantPimpleFoam: test case
Like Tree2Likes
  • 2 Post By tian
Old   June 5, 2013, 10:35
Default buoyantPimpleFoam: test case
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I am trying to set up a case with the solver buoyantPimpleFoam, but I can't make the simulation start.
Attached a test case. If you launch it (execute the blockMesh, first), you get an error. Immediately.
Could you have a look?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   June 6, 2013, 06:49
Samuele Z
This is the error that you get, when launching the solver:
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/testTransient$ buoyantPimpleFoam
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : buoyantPimpleFoam
Date   : Jun 06 2013
Time   : 12:45:38
Host   : "lab-laptop"
PID    : 4188
Case   : /home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/testTransient
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model realizableKE
realizableKECoeffs
    Cmu             0.09;
    A0              4;
    C2              1.9;
    sigmak          1;
    sigmaEps        1.2;
    Prt             1;
Calculating field g.h
Reading field p_rgh
Creating field dpdt
Creating field kinetic energy K
Courant Number mean: 0.0340283 max: 0.371779
PIMPLE: Operating solver in PISO mode
Starting time loop
Time = 0.0001
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/buoyantPimpleFoam"
#9  __libc_start_main in "/lib/libc.so.6"
Floating point exception
It seems that there is a division by zero. But where is it? And why this happens? Because of the wrong BC?
Old   June 7, 2013, 02:08
Default Other Test Case
Tian
tian is on a distinguished road
here is an other test case for you. Maybe you compare with your case...
Bye
Tian
samiam1000 and Tobi like this.
tian is offline   Reply With Quote
Old   June 9, 2013, 12:28
Samuele Z
Thanks a lot: Im gonna test it!
Old   June 11, 2013, 03:49
Samuele Z
Hi Tjan,
I can't open the archive. It seems corrupted. Could you check it, please?
Thanks a lot,
Samuele
Old   June 11, 2013, 06:22
Tobi's Avatar
Tobias Holzmann
Tobi will become famous soon enoughTobi will become famous soon enough
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
it s not possible for me to test your case but set a value in the file p:
inlet
type buoyantPressure;
value $internalField;
And set a value for every "zeroGradient" BC (just to be safe)
That is the only hint at the moment
Tobi is offline   Reply With Quote
Old   January 8, 2014, 13:04
Jamal
aujamal20 is an unknown quantity at this point
Originally Posted by Tobi View Post
inlet
I am working on buoyantPimpleFoam case. I prepared a wedge shaped geometry and using almost similar setting as of hotRoom tutorial. As the simulation is started the deltaT starts decreasing and keep continue to decrease and reaches upto the power of 1e-5/6 and then it stop with an error message of "iterations exceeded".
Is there any possible way to run a stable simulation with buoyantPimpleFoam. working on OF 2.2.x
Regards,
Jamal
aujamal20 is offline   Reply With Quote
Thread Tools
Trackbacks are On
rhoSimpleFoam - test case atareen64 OpenFOAM Running, Solving & CFD 5 May 1, 2011 17:17
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 14 March 8, 2011 09:19
Help Required With Simple Test Case steph79 OpenFOAM Pre-Processing 4 August 3, 2010 07:45
3D TRANSITION TEST CASE venkatesh4386@gmail.com FLUENT 0 March 9, 2009 13:04
Porous Media test case Alex FLUENT 0 April 9, 2006 08:23
