June 5, 2013, 19:50 |
Which model should I choose?
Dongyue Li
Rep Power: 17 |
Hi All,
Recently I am uncertain which model I should use in my project. Its a gas-liquid mixing system, but the liquid is xanthan gum. When gas is injected into xanthan gum. the flow type is kind like slug flow. Look the image 3, So there are many fine bubbles and some big gas slugs. Until now I am willing to choose VOF or Euler-Euler model. 1. Regarding VOF, as of the mesh reason, in the simulation there would not have this fine bubbles. but I can have this big gas slugs. 2. Reagrding Euler-Euler model, I am not sure what the reault looks like. I only made a test about air-water system. But I heard two fluid model cannot deal with seperation rite? Any ideas ? BTY, in experiment, which method do you use if you want to get global gas hold up or local bubble size? Now I am using expansion technique. But the liquid level fluctuate woo much which affect my global gas hold up badly. Thanks in advance. |
June 6, 2013, 05:40 |
#2 | |
OJ
Rep Power: 20 |
VOF seems a strong contender. Since the the bubbles are of really large size having a distinct interface. But be aware that you will need a very fine mesh if you want to capture the interface.
I was wondering, if this is a tank, do you specify the top surface as free surface or degassing boundary condition (using UDF)? OJ |
June 6, 2013, 23:36 |
#3 | |
Dongyue Li
Rep Power: 17 |
I am using OpenFOAM, I dont need to specify the gas-liquid interface's B.C. in the tank's outlet, I make U's zerogradient and pressure is fixedvalue. so in FLUENT I am not quite familiar with that, Sorry about that. In OpenFOAM, there is no PBM, so I have to implent it by myself which its very tough for me. Regarding VOF, Have you ever made a test to see the viscosity field? I have some of this unnormal viscosity problems...In OpenFOAM, if the liquid's viscosity is changing (non-newtonian fluid), all of the viscosity include the air's is the same. I dont know if this exists in FLUENT? Thanks for your reply. |
June 7, 2013, 06:52 |
OJ
Rep Power: 20 |
I see, I think you are on the wrong forum then. Try posting it on OPENFoam forum?
OJ |
What turbulent flow model choose in Fluent | ja.maldonado1187 | FLUENT | 2 | August 11, 2013 06:33 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 19:13 |
what constants to choose for std k-e model | daniel.struwig | FLUENT | 0 | April 18, 2009 06:51 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
