velocity is going beyond its initial value
Old   June 8, 2013, 06:56
Default velocity is going beyond its initial value
Ank
ankur
Ank is on a distinguished road
Hey
This thread is related to the thread http://www.cfd-online.com/Forums/ope...r-channel.html
Initially I was using the buoyantBoussinesqSimpleFoam solver to simulate air flow inside a heated rectangular channel or pipe. The velocity was 1 m/s at the inlet but it increased to 1.1 m/s as it approached the outlet.
After that I have modified the simpleFoam solver and added T equation in it (Based on the guidelines given at http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam)
I am not so sure whether I have done it rightly or not, but it is running good. The problem is that the results are similar to buyoant solvers and not good.
I m not able to understand the reason.
Any suggestion?
Ank is offline   Reply With Quote
Old   June 8, 2013, 08:40
Nima Samkhaniani
nimasam is on a distinguished road
Dear ankur
whats wrong with velocity result? it may differ from initial condition and its not wrong at all , you may give a uniform velocity at inlet, but when it reaches outlet, velocity profile will be changed, it reduces near wall for no slip condition and get sharper at the middle plane and have a value more than 1 m/s, i think you should provide some plots here to show us what is wrong?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 8, 2013, 09:07
Ank
ankur
Hey nima sam
Thanks alot for your reply..
I think I got your point. It was silly from my side. I did not check the results (without temperature case) properly. I did it again and waited for more time. It is giving the same result as with the temperature.
but the positive point is I understood how it happens now, and learned how to modify the solver
Thanks alot..I think to have a mass balance velocity peaks at a certain point.
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
