Beginner: questions about mixerVesselAMI2D blockmesh
Old   June 10, 2013, 03:59
Default Beginner: questions about mixerVesselAMI2D blockmesh
Anand Lobo
Boloar is on a distinguished road
Hey all.
I'm still quite new to OpenFOAM and CFD in general.
I'm looking at the constant/polyMesh/blockMeshDict.m4 in the incompressible/pimpleDyMFoam/mixerVesselAMI2D tutorial, and where the vertices are defined (lines 315-438) they appear to be duplicated with different names in several places.
Is this required for the AMI to function? If so, could you outline why?
Thanks.
Boloar is offline   Reply With Quote
Old   June 10, 2013, 04:23
Default Modifying the non-AMI region
Anand Lobo
How would I go about defining the non-AMI (stator) region as a square, so that I can model the mixer with an inflow / outflow?
As I understand it, the AMI region and non-AMI region must be perfectly lined up - I'm unsure how I would maintain the interface between the circular AMI and a non-circular outer mesh.
ami, new to cfd
UDF link fortran source yorelchr Fluent UDF and Scheme Programming 0 February 7, 2013 03:44
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
[Technical] how to order the vertices in blockMesh? andrei.cimpoeru OpenFOAM Meshing & Mesh Conversion 2 December 11, 2012 13:17
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
[blockMesh] Does blockMesh create mesh vertices in any particular order brooksmoses OpenFOAM Meshing & Mesh Conversion 3 December 12, 2005 20:26
