September 2, 2011, 05:39 |
Moving Mesh
linda zhang
Rep Power: 15 |
Hi, Foamers
I would like to simulate the bed morphology. There is one moving boundary(sea bottom) in the computation domain. The movement (Ux, Uy, Uz) of that boundary is determined by Exner equation and changes with time. 1. Could movingConeMotion in icoDyMFoam in OF-1.5-dev solve the problem I mentioned before? 2. If so, in dynamicMeshDict, does twoDMotion mean that there are two direction movements of the boundary mesh points?How can I transfer the movement of the boundary to the solver? Which boundary condition should I use? 3. If no, could you help to suggest which way I should go? Thanks Linda |
September 2, 2011, 06:14 |
what about http://www.openfoamworkshop.org/6th_...liu_slides.pdf Fruitful Modeling and Research Efforts by the Environmental Fluid Mechanics Group using OpenFOAM at University of Texas at San Antonio, TX , Xiaofeng Liu I just searched for seabed openfoam at google scholar |
September 5, 2011, 03:29 |
linda zhang
Rep Power: 15 |
Hello,elvis:
Thanks. I read Dr. Liu's thesis and paper. However, I am wondering whether there is a tutorial as this case. Does it take longer time to do the tactics or not? regards Linda |
September 5, 2011, 06:27 |
Dear Linda,
just saw that there is some work in these area http://powerlab.fsb.hr/ped/kturbo/Op...006-jsc-16.pdf http://gradworks.umi.com/3314965.pdf Tutorials / tutorial cases are often provided by a Special Interest Group (SIG) that is working in that area http://www.extend-project.de/user-groups/11/groups list some SIG that have founded For "moving mesh" there are different stategies =>http://www.openfoamworkshop.org/6th_...ney_slides.pdf Adaptive Tetrahedral Re-Meshing for Deforming Domains, K. Mooney, UMass Amherst So you have to sort out which of them is the right one for your problem Last edited by elvis; September 5, 2011 at 06:45. |
June 18, 2013, 13:02 |
kingleli
Rep Power: 14 |
Hi, I think we are doing the similar work, I know some method of modeling morpholoy migration,such as Two-phase, FAM & automesh deformation , etc. But I think the classic method is moving mesh according Exner equation(sediment continuty), because the interface between the water and riverbed is sharp and not the mixture, so I don't think the FAM or two - phase method are appropriat for your project.I just know the theory about this method (I have read XiaofengLiu's paper) . However, I don't realize it. Because my knowledge on C++ is poor Now , i have been working on the sediment transport, especially on the bed load. If you have interest, we can communicate with each other, looking for your reply.
Display Modes | |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
How to let the mesh motion solver just solve a small region near a moving boundary? | zhajingjing | OpenFOAM Running, Solving & CFD | 9 | April 28, 2016 05:15 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
CavitatingFoam with a moving mesh mass conservation error | idosil | OpenFOAM Running, Solving & CFD | 3 | November 27, 2007 18:27 |
Waves halted by moving mesh | Piotr Czajko | COMSOL | 1 | November 24, 2007 03:00 |
