is the limitation of maximum 24h run in OF true? |
June 25, 2013, 18:57 |
Ehsan
Rep Power: 26 |
i had read in a thread here that a hard coded part in OF code prevents to run over 24h,i need to run more than 60h.is it true in new versions or not longer?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 25, 2013, 20:44 |
Masashi Ohbuchi
There is not a run time limitation in OpenFOAM source code. It might be a limitation due to the batch queue management system. |
June 26, 2013, 05:22 |
Mohsen KiaMansouri
There is not such a thing. I have a run that continues over a month!
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
June 26, 2013, 05:30 |
Ehsan
Rep Power: 26 |
I think it has been in earlier versions,because I saw it in a very old post that can't find again.well its good if it has been raised.
crash:parallel run and writetime? | calim_cfd | OpenFOAM Bugs | 2 | March 5, 2012 19:13 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Cycling a transient run | Chetan Mistry | Phoenics | 0 | March 3, 2004 09:50 |
