particles parallelization transfere cloud move |
July 2, 2013, 13:55 |
Hi All,
i ran into a huge problem and i need help! I am doing a LES-PDF method using MC particles and the particles carry a lot of information (each particle has about 35 doubles which are transfered via stream and not reinitiated by a preinitialization list). The paralellization is REALLY bad! Using 48 cores - one board, quadsocket, xeon cpus - the time is spend as follows (318087 LES cells, 1556621 particles ): - 99.4 % of the time is used for particles(rest for LES) - The particle move takes 96.7 % of the particle time - and the transfer takes 94 % of that time so essentially the computer is only bussy moving particles. The routine consuming all the resources (in myCloud.move() ) is Code:
while ( true ) <- what the heck is that deathloop any ways !? .... .... .. if (!Pstream::parRun()) { break; } // Allocate transfer buffers PstreamBuffers pBufs(Pstream::nonBlocking); // Stream into send buffers forAll(particleTransferLists, i) { if (particleTransferLists[i].size()) { UOPstream particleStream ( neighbourProcs[i], pBufs ); particleStream << patchIndexTransferLists[i] << particleTransferLists[i]; } } // Set up transfers when in non-blocking mode. Returns sizes (in bytes) // to be sent/received. labelListList allNTrans(Pstream::nProcs()); pBufs.finishedSends(allNTrans); bool transfered = false; forAll(allNTrans, i) { forAll(allNTrans[i], j) { if (allNTrans[i][j]) { transfered = true; break; } } } if (!transfered) { break; } // Retrieve from receive buffers forAll(neighbourProcs, i) { label neighbProci = neighbourProcs[i]; label nRec = allNTrans[neighbProci][Pstream::myProcNo()]; if (nRec) { UIPstream particleStream(neighbProci, pBufs); labelList receivePatchIndex(particleStream); IDLList<myHardBallParticle> newParticles ( particleStream, //typename myHardBallParticle::iNew(polyMesh_) myHardBallParticle::iNew(*this) ); label pI = 0; forAllIter(myIncompressibleCloud, newParticles, newpIter) { myHardBallParticle& newp = newpIter(); label patchI = procPatches[receivePatchIndex[pI++]]; newp.correctAfterParallelTransfer(patchI, td); addParticle(newParticles.remove(&newp)); } } I would appreciate any ideas or comments!!! |
how to determine the number of particles injected. | welch | FLUENT | 2 | January 18, 2024 05:08 |
UDF for deleting particles in DPM | imanmirzaii | Fluent UDF and Scheme Programming | 12 | November 25, 2020 20:27 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 22:33 |
Straight through cyclone with particles | rogerhoffmann | CFX | 1 | May 21, 2012 19:42 |
particles model | ati_ros61 | FLOW-3D | 3 | December 6, 2009 17:03 |
