UEqn.relax()
Like Tree14Likes
  • 1 Post By mugi
  • 1 Post By giack
  • 3 Post By santiagomarquezd
  • 3 Post By Bernhard
  • 1 Post By giack
  • 5 Post By cfdonline2mohsen
Old   December 7, 2011, 09:35
Default UEqn.relax()
Maike
mugi is on a distinguished road
In the PIMPLE algorithm the momentum equation is defined and afterwards used by UEqun.relax(). As far as I could figure out this means that an underrelaxation is applied, but what does this relax do exactly or where is it defined in the code?
Thanks for any help!
Maike.
immortality likes this.
mugi is offline   Reply With Quote
Old   June 20, 2013, 05:11
giack is on a distinguished road
Do you find the answer at your question? I have the same question. Moreover in my fvSolution file I don't specify any under relaxation factor..
Thanks
giack is offline   Reply With Quote
Old   July 2, 2013, 23:14
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
http://foam.sourceforge.net/docs/cpp/a04763_source.html, line 524
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   July 3, 2013, 01:41
immortality's Avatar
Ehsan
immortality is on a distinguished road
it isn't clear how the relaxation is applied even in the code.
Where alpha is defined?
Can we set it and whats alpha at all?
How relaxation is applied?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 3, 2013, 01:51
Bernhard
Bernhard is on a distinguished road
See line 658 of the same file, the relax() member function without argument is defined. Then, the parameter are read from a file, as here http://foam.sourceforge.net/docs/cpp...ce.html#l00313
Note that on the docs, you can search for member functions that you want to find (I used it on "equationRelaxationFactor")
Bernhard is offline   Reply With Quote
Old   July 3, 2013, 05:17
So if I don't specify any relaxation factor in fvSolution file the relaxation is not applied to equation,it's right?
Old   July 3, 2013, 08:39
Ehsan
its not obvious enough to find out how automatically this relaxation is implemented yet,how can avoid relaxation?
Old   July 3, 2013, 13:06
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Thanks Santiago & Bernhard
If you don't specify any under relaxation factor then the default is zero
00099         eqnRelaxDefault_ =
00100         eqnRelaxDict_.lookupOrDefault<scalar>("default", 0.0);
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.”
cfdonline2mohsen is offline   Reply With Quote
