Home > Forums > OpenFOAM
whats the trick to access to second layer of patch neighbors in groovyBC?
Like Tree4Likes
  • 1 Post By gschaider
  • 2 Post By gschaider
Old   July 8, 2013, 20:49
Default whats the trick to access to second layer of patch neighbors in groovyBC?
immortality's Avatar
Ehsan
immortality is on a distinguished road
i want to use an expression on outlet so that the pressure on the patch be to say 100000 less than internalField,
But for more smoothness its good to have access and participate second layers of neighbors in expression too.
How can do it?is it possible or not(with or without groovyBC)?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 9, 2013, 05:43
Assistant Moderator
Bernhard Gschaider
Not possible in groovyBC. And hard to do in C++ (part of the problem is that "second layer of cells" is only well-defined for a pure hex-mesh and even then you have corner-cases ... on the corners)
immortality likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 9, 2013, 05:59
Ehsan
thanks.
what does "corner-cases" mean?
Old   July 9, 2013, 07:14
Assistant Moderator
Bernhard Gschaider
thanks.
http://bit.ly/14FRisK
sylvester and startingWithCFD like this.
Old   July 9, 2013, 07:58
Ehsan
what interesting site! google was filtered some days ago!
but I mean what corner cases may occur,in what sense?
Old   July 9, 2013, 10:14
Assistant Moderator
Bernhard Gschaider
Draw a regular grid with a corner (concave and convex) on a piece of paper and think what the second layer of cells is. In one case you have cells from the first layer in the second layer. In the other case there are cells missing that should have an influence. And that is an easy case
Old   July 9, 2013, 12:01
Ehsan
yes you right,that issue is for one or three cell but may be somewhat hard to write a program that realizes it but I have a thesis that have done it,I'll try to do this maybe some months later(after being light my works)and share!
now I think gradientExpession "-50000" for example works fine enough(acceptable).
Thread Tools
Trackbacks are On
How to access to faces of a patch jaswi OpenFOAM Running, Solving & CFD 14 August 24, 2016 07:52
Access patch points (on different processor) in parallel Arnoldinho OpenFOAM Programming & Development 7 September 11, 2012 05:55
Can groovyBC (swak4foam) access dimensionedScalar? argonaut OpenFOAM Running, Solving & CFD 1 May 24, 2012 09:04
How to get access to normalVectors of specified faces in patch tilo OpenFOAM Programming & Development 0 April 27, 2012 19:59
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
