Choosing l in external aero simulation & nu used in motorbike tutorial |
November 28, 2017, 12:39 |
Ed O'Malley
Rep Power: 8 |
Hi - new to OpenFoam. I'm working on an external aerodynamic simulation of a bike part - about 200mm in length, 70mm in width. I'm using the motorbike demo as a base to start from. Overall force results in the simulation seem low (0.1 to 0.2N at 10m/s air velocity - force is reported in N, right?), so I was going over some of the boundary conditions and I came up with a few questions -
The manual clearly describes how to calculate the turbulence length scale in pipe flow problems - but how is it done in external aerodynamic cases? The motorbike and the simple car tutorials both use 1e-5 as the kinematic viscosity of air, but at 20C it is actually 1.5e-5 m^2/s. Is there a reason to choose the lower viscosity if I am simulated a full-scale model? Thanks! |
external aerodynamics, kinematic viscosity, turbulent length scale |
Inside of the motorbike tutorial | meth | OpenFOAM | 0 | March 20, 2017 01:06 |
[OpenFOAM] empty volumefield in motorbike tutorial | CFDummy | ParaView | 0 | August 10, 2016 14:01 |
Change MotorBike Tutorial to Water | connoranderson | OpenFOAM Running, Solving & CFD | 0 | January 7, 2015 20:57 |
Usefulness of Similarity theory in External Aero | Amod Kumar | Main CFD Forum | 2 | January 10, 2007 04:58 |
