May 3, 2012, 09:41 |
Add Random value to velocity
Jian Zhong
Rep Power: 14 |
Dear Foamers,
How to add random value to velocity in the solver using LES? I just want to see larger eddies in a shorter time? It may relate to Random.H function. But how to link it to velocity? I have no experience of using Random.H. |
May 3, 2012, 13:18 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Description Generate a fluctuating inlet condition by adding a random component to a reference (mean) field. Input: referenceField Mean field. fluctuationScale RMS fluctuation, provided as the fraction of the mean field. alpha temporal correlation factor; the fraction of the new random component added to the previous time-step (defaults to 0.1). |
May 3, 2012, 15:50 |
Jian Zhong
Rep Power: 14 |
Thanks. But my BC is cyclic. I want to add a perturbation component to velocity vector. I noticed that perturbU utility can be useful. But I do not know how to do that.
July 10, 2013, 16:21 |
Negin Nazarian
Rep Power: 14 |
Hi Jian,
I was wondering if you were able to introduce the perturbation and how?. I also have a LES simulation with periodic BC and I want to add random u,v,w fluctuations (having rms values equal to friction velocity) to trigger turbulence and I dont know how to do it in Fluent. I would appreciate your help. Cheers, Negin |
July 11, 2013, 11:29 |
Jian Zhong
Rep Power: 14 |
Dear Negin,
I am sorry that I have not make it. I just use pressure gradient to drive my flow (just as the ChannelFoam tutorial) and select LES model in the turbulence directory. Also, I am not familiar with Fluent. But, you may try...... U = U+Random()*FACTOR My best regards, Jian |
random, velocity |
Display Modes | |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 19:08 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
is there any method give node based velocity BC? | daniel | FLUENT | 2 | July 18, 2006 21:21 |
Velocity Under-relaxation in SIMPLE type methods | Matt U. | Main CFD Forum | 6 | July 4, 2005 05:29 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
