stitchMesh -partial AMI1 AMI2
Hi Foamers,
I want to stitchMesh -partial AMI1 AMI2 command to remove and stitch two AMI surfaces for a propeller domain through OF2.1x. I used this command already for a simple case but when applying for my case I face this error: From function void enrichedPatch::calcCutFaces() const in file slidingInterface/enrichedPatch/enrichedPatchCutFaces.C at line 624. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/bin/stitchMesh" #3 Foam::enrichedPatch::calcCutFaces() const in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libdynamicMesh.so" #4 Foam::enrichedPatch::cutFaces() const in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libdynamicMesh.so" #5 Foam::slidingInterface::coupleInterface(Foam::poly TopoChange&) const in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libdynamicMesh.so" #6 Foam::slidingInterface::setRefinement(Foam::polyTo poChange&) const in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libdynamicMesh.so" #7 Foam::polyTopoChanger::topoChangeRequest() const in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libdynamicMesh.so" #8 Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool) in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/lib/libdynamicMesh.so" #9 main in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/bin/stitchMesh" #10 __libc_start_main in "/lib64/libc.so.6" #11 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/beda/sw/apps/OpenFOAM/2.1.x-20120311/OpenFOAM-2.1.x/platforms/linux64IccDPOpt/bin/stitchMesh" Aborted my boundaryDic is as below: AMI1 { type cyclicAMI; nFaces 77070; startFace 43674918; matchTolerance 1e-5; neighbourPatch AMI2; transform noOrdering; } AMI2 { type cyclicAMI; nFaces 67364; startFace 43159648; matchTolerance 1e-5; neighbourPatch AMI1; transform noOrdering; } I look forward to hear from you. Thanks Already |
please notice this problem that is exact mine.
http://www.cfd-online.com/Forums/ope...h-problem.html |
