Adaptive Mesh refinement for steady state solver |
July 17, 2013, 13:35 |
#1 | |
Haomin Yuan
Hey, all,
I have a problem about adaptive mesh refinement. I looked around all the solver, it seems all the solver that can do AMR is transient solver. Does anyone know if there is a existing AMR steady solver? I also tried to implement AMR into rhoSimplecFoam solver. The procedure was simple, but I met error. I added mesh.update() in the solver. The error info is : Quote:
thank you in advance~ |
July 18, 2013, 01:55 |
Akshay Kumar
Hey!
Is your cacheAgglomeration off? Try that. |
July 18, 2013, 12:07 |
Haomin Yuan
Yes, this is the problem. I worked it out.
thank you |
August 20, 2013, 04:11 |
Dear Haomin,
Did you just add mesh.update() in your solver? Is it sufficient to have adaptive mesh refinement for any steady state solver? Regards, Hossein |
August 20, 2013, 11:47 |
Haomin Yuan
Hi, you also have to use "dynamicMesh" class to construct mesh. You can easily find examples in solvers that used dynamicMesh.
And, yes, the sentence that make difference is "mesh.update()". |
April 12, 2017, 07:35 |
Jeroen
Rep Power: 9 |
I'm also trying to implement adaptive meshing in my simpleFoam solver, but I seem to get the following error when I include mesh.update(); in my Simple Loop. error: 'class Foam::fvMesh' has no member named 'update' I've been trying to look at pimpleDyMFoam and use this as a starting point for my simpleFoam solver. Any ideas how I can tackle this problem? |
Adding adaptive mesh refinement to the forwardStep tutorial | AlphaSheep | OpenFOAM Running, Solving & CFD | 10 | August 3, 2019 15:40 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 04:59 |
adaptive mesh refinement in STARCCM+ | abdullahkarimi | Siemens | 1 | November 16, 2010 19:26 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Mesh generator and CFD solver | Gennady Kireyko | Main CFD Forum | 0 | May 6, 2001 12:13 |
