Home > Forums > OpenFOAM
use paraview to visualize the openfoam output results
Old   July 22, 2013, 15:33
Question use paraview to visualize the openfoam output results
hz283 is on a distinguished road
Hi All,
When I finish a parallel computation, for example 8 coes, when I would like to see the results with paraview, now I always first use the command reconstruct to combine the data and then the paraview to open them. I am wondering if there is a method to see the results using paraview without combing the data first. Because if the data are very large then the combining is very time consuming and comsume lots of space.
Thank you very much.
hz283 is offline   Reply With Quote
Old   July 23, 2013, 01:39
Bernhard
Bernhard is on a distinguished road
Select "Decomposed Case" from Case Type, instead of Reconstructed Case"
Bernhard is offline   Reply With Quote
Old   July 23, 2013, 08:18
Question
So simple......I have not noticed this function. Thank you so much.
Thread Tools
Trackbacks are On
Questions about Paraview to show Parallel run of OpenFOAM padian OpenFOAM Post-Processing 14 May 8, 2016 10:55
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) sfigato OpenFOAM Installation 22 January 31, 2013 11:16
Visualize results from ANSYS Ls-Dyna, mechanicaldesign ANSYS 0 January 22, 2013 00:37
Velocity vector data in OpenFOAM and ParaView mismatch tekky OpenFOAM 9 December 21, 2009 12:26
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 03:14
