-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Where are correct () and update() functions defined ? (http://www.cfd-online.com/Forums/openfoam/121243-where-correct-update-functions-defined.html)
sasanghomi July 24, 2013 10:14
Hi Foamers,
I am focusing the codes of sonicTurbDyMEngineFoam these days.
Do you know where is the correct() function defined in below code ?
thermo.correct();
And where is update() function defined in below code ?
bool meshChanged = mesh.update();
I appreciate your help.
Thanks and best regards,
Sasan.
P.S. correct function declared as a pure virtual function in basicThermo class.
yhaomin2007 July 24, 2013 11:00
For the first question "thermo.correct();"
It depends on what thermo model you are using. Take hPsiThermo as an example.
It is define in
/src/thermophysicalModels/basic/psiThermo/hPsiThermo/hPsiThermo.C
For the second question. This is used dynamic meshing.It also depends on what dynamic meshing utility you are using. If you use dynamicRefineFvMesh
It is defined in
/src/dynamicFvMesh/dynamicRefineFvMesh/dynamicRefineFvMesh.C
sasanghomi July 24, 2013 11:44
Dear Haomin
Thank you very much.
Best regards
Sasan.
immortality August 15, 2013 15:04
Hi Sasan,Haomin and other dears
what does correct() do on thermo type?
I can't find thermo.correct() in the library below:
  \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox
  \\    /  O peration    |
    \\  /    A nd          | Copyright (C) 2011-2012 OpenFOAM Foundation
    \\/    M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "hePsiThermo.H"
// * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
template<class BasicPsiThermo, class MixtureType>
void Foam::hePsiThermo<BasicPsiThermo, MixtureType>::calculate()
    const scalarField& hCells = this->he_.internalField();
    const scalarField& pCells = this->p_.internalField();
    scalarField& TCells = this->T_.internalField();
    scalarField& psiCells = this->psi_.internalField();
    scalarField& muCells = this->mu_.internalField();
    scalarField& alphaCells = this->alpha_.internalField();
    forAll(TCells, celli)
        const typename MixtureType::thermoType& mixture_ =
            this->cellMixture(celli);
        TCells[celli] = mixture_.THE
            hCells[celli],
            pCells[celli],
            TCells[celli]
        psiCells[celli] = mixture_.psi(pCells[celli], TCells[celli]);
        muCells[celli] = mixture_.mu(pCells[celli], TCells[celli]);
        alphaCells[celli] = mixture_.alphah(pCells[celli], TCells[celli]);
    forAll(this->T_.boundaryField(), patchi)
        fvPatchScalarField& pp = this->p_.boundaryField()[patchi];
        fvPatchScalarField& pT = this->T_.boundaryField()[patchi];
        fvPatchScalarField& ppsi = this->psi_.boundaryField()[patchi];
        fvPatchScalarField& ph = this->he_.boundaryField()[patchi];
        fvPatchScalarField& pmu = this->mu_.boundaryField()[patchi];
        fvPatchScalarField& palpha = this->alpha_.boundaryField()[patchi];
        if (pT.fixesValue())
            forAll(pT, facei)
                    this->patchFaceMixture(patchi, facei);
                ph[facei] = mixture_.HE(pp[facei], pT[facei]);
                ppsi[facei] = mixture_.psi(pp[facei], pT[facei]);
                pmu[facei] = mixture_.mu(pp[facei], pT[facei]);
                palpha[facei] = mixture_.alphah(pp[facei], pT[facei]);
        else
            forAll(pT, facei)
                pT[facei] = mixture_.THE(ph[facei], pp[facei], pT[facei]);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::hePsiThermo<BasicPsiThermo, MixtureType>::hePsiThermo
    const fvMesh& mesh,
    const word& phaseName
    heThermo<BasicPsiThermo, MixtureType>(mesh, phaseName)
    calculate();
    // Switch on saving old time
    this->psi_.oldTime();
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::hePsiThermo<BasicPsiThermo, MixtureType>::~hePsiThermo()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void Foam::hePsiThermo<BasicPsiThermo, MixtureType>::correct()
    if (debug)
        Info<< "entering hePsiThermo<BasicPsiThermo, MixtureType>::correct()"
            << endl;
    // force the saving of the old-time values
    calculate();
    if (debug)
        Info<< "exiting hePsiThermo<BasicPsiThermo, MixtureType>::correct()"
            << endl;
yhaomin2007 August 15, 2013 15:06
It calculate other properties from pressure and h or e.
dkxls August 16, 2013 09:49
thermo.correct() is just a wrapper for thermo.calculate(). See the code below for an example.
This has been discussed here already some time ago, search the forum and you will find more information.
    if (debug)
            << endl;
    calculate();
    if (debug)
            << endl;
