July 24, 2013, 15:14 |
install in OF 2.1 error
david
Rep Power: 11 |
Good Day Folks,
I try to install swak4Foam in Openfoam 2.1, I follow these steps Step 1: [ svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ ], copy & paste in terminal window step 2: [ hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam ] copy & paste in terminal window upto this step it works step 3: [ hg update port_2.0.x ] copy & paste in terminal, I got error like this, toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/swak4Foam$ hg update port_2.0.x abort: no repository found in '/home/toshiba/OpenFOAM/toshiba-2.1.0/swak4Foam' (.hg not found)! kindly let me the step 3 is necessary? just I tried. step4: ./Allwmake --->copy & paste in terminal window, I got error like, toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/swak4Foam$ ./Allwmake No 'swakConfiguration'. Python etc won't work Checking swak4Foam-version and generating file abort: no repository found in '/home/toshiba/OpenFOAM/toshiba-2.1.0/swak4Foam' (.hg not found)! Swak version is 0.2.4 No 'bison' found. This is absolutely essential for swak4Foam. Can't go on Requirements for Library not satisfied. I see no sense in going on toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/swak4Foam$ Kindly help me
Million Thanks, David "Small Dream is a Crime" |
July 24, 2013, 17:13 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request Last edited by gschaider; July 24, 2013 at 17:19. Reason: Add closing paranthesis |
July 25, 2013, 00:18 |
david
Rep Power: 11 |
Thanks for suggestion gschaider, finally I did, Now it works fine
I understand the problem, but you are telling , you didn't use Ubuntu, that the reason I start new thread, kindly let know any simple trick, to get more help without making annoying our OF folks.I am new to OF. And also let me know which one are you using for OF.
Million Thanks, David "Small Dream is a Crime" Last edited by psk; July 25, 2013 at 04:32. |
July 25, 2013, 05:13 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Concerning the installation of bison: http://bit.ly/144S7Pf The second link (http://en.kioskea.net/faq/30635-how-...n-under-ubuntu) looks nice (and there is a number of other links that looks promising)
July 25, 2013, 11:48 |
david
Rep Power: 11 |
Good Day, Thanks for your reply & information gschaider,
I already did that one, kindly see this link (http://www.cfd-online.com/Forums/ope...tml#post441825 ) Also Kindly let me know, how to convert matlab m file to python? I go through this link:[ http://ompclib.appspot.com/m2py ], while running the converted python script it shows lot of error, I am new to python. If you have any idea share me.
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
